555 Timer Pulse Generator @ Approx 1020 Hz
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 03/29/2017 at 13:160 Comments
I put together a simple pulse generator, using a 555 timer chip from a schematic from an old Forest Mims notebook of mine, so I could calibrate the MCU and MegunoLink Pro to work together when I get ready to link the CCD to the ATmega1284.
These are the results below and they are beautiful :)
Final Plot, 4.47vdc @ 0.26mA
Code used for this test;
#include "MegunoLink.h" // Helpful functions for communicating with MegunoLink.
// Millis value when the data was last sent.
long LastSent;
// Interval (milliseconds) between sending analog data
const unsigned SendInterval = 200; // [ms]
// The plot we are sending data to.
TimePlot MyPlot;
void setup()
Serial.begin(115200);
LastSent = millis();
MyPlot.SetTitle("PulseTestProgram");
MyPlot.SetXlabel("Frequency Hz");
MyPlot.SetYlabel("MilliSeconds");
MyPlot.SetSeriesProperties("GeneratorValue", Plot::Magenta, Plot::Solid, 2, Plot::Square);
void loop()
if ((millis() - LastSent) > SendInterval)
int DataValue = analogRead(PA0);
MyPlot.SendData("GeneratorValue", DataValue);
This plot is using a 10k Pot @ 4.53vdc
Pulse at 4.98vdc
Pulse at 4.13vdc
Pulse at 4.27vdc
