Progress Update
A project log for GPSDO IEEE PTP Master
GPS disciplined DCXO with software temperature compensation and IEEE 1588 PTP master
Robert RouquetteRobert Rouquette 05/28/2022 at 23:490 Comments
I've implemented SNMP and the GPSDO logic.  The software is currently using the frequency trimming support in the PTP hardware to under-clock the PPS and steer the edge alignment.  Otherwise, the temperature compensation and PLL logic are working as expected.  I still need to make a breakout board for the DXCO and I2C temperature sensor.
Temperature Compensation:
PPS Tracking:
Comparison against GPS NTP server:
