1. Bimetallic Injection Screw & Barrel Use to deliver the plastic pellets into the barrel and inject the plastic after melted the pellets. - Size: 20mm (Good enough for injects 50 - 100 grams product weight) - Quantity: 1
2. Injection Machine Band Heater Use to melt the plastic pellets Quantity: 2 - 3 Size: will update later
3. 0-400℃ LED PID AC110V-240V Temperature Controller Digital Use to control the band heaters' temperature Quantity: 2 - 3
4. Shaft Coupler Use to connect the motor to the screw
5. Motors Still doing research for motors which is compatible with the machine, any suggestion would be helpful.
