In addition, PEMF therapy improves sleep, mental focus, and the body’s overall performance by helping the energy output and regeneration of the body’s cells.
Clinical studies have demonstrated that PEMFs are capable of:
Increasing circulation
Decreasing inflammation
Accelerating bone healing
Enhancing muscle function
Reducing the effects of stress
Improving blood oxygenation, and much more.
This project is sponsored by PCBgogo: https://www.pcbgogo.com
The construction of this device is based on commercial such devices that are sold at a price of several hundred to thousands of dollars. My goal is to make the simple to build and functional device available to more people who can not afford it.
For that purpose, I made the device completely from ready-made modules, so that its production requires only a basic knowledge of electronics and soldering. Thus the cost of the device without power supply does not exceed 10 dollars
It is extremly simple and consist only a few components:
- 19V Power supply from old Laptop computer
- Potentiometer
- MOSFET Trigger Switch Drive Module
- and small signal generator module
And now a few words about making the coil:
Depending on which part of the body we use the device, different coils can be made.They should have inductance of about 15 micro H. I made two different coils: one contains 200 winding copper wire(from 0.2 to 0.4 mm2) on an air core with a diameter of 17 cm ,and second for a stronger and focused magnetic field you can make a smaller diameter coil but you have the same impedance . For example, a 8 cm diameter coil should have approximately 300 windings. You can create a customized coil after calculations by coil calculator given oh the link below:
https://www.66pacific.com/calculators/coil-inductance-calculator.aspx
It is important that the ohmic resistance of the coil should not be less than 4 ohms. Тhe intensity of the magnetic flux is approximately 20 Gaus.
I am not a medical person and I can not discuss the effect of the device, although I personally have many positive experiences from using it. I can also say with certainty that low frequency magnetic fields definitely have no negative impact, except in people where it is contraindicated(Pregnancy,Pacemakers,bleeding,Active tuberculosis,Malignancies). In fact, MRI imaging uses magnetic fields that are thousands of times stronger than those at PEMF and we all know that this imaging is completely harmless.
Finally, the device is mounted in a suitable plastic box coated with self-adhesive wallpaper.
mircemk
Hi , I am interested in building your project, but am having some trouble with the coil calculations. I tried to estimate some of the numbers you used on this link
http://production-solution.com/coil-calculator.htm but did not get the resistance or Micro Henry results you did. Could you give me some of the numbers you used so I can create a correct coil? Thanks much for you post.
