Now lets check if the Board fits inside the old housing.
A First Size Comparison looks great.
So we can still use the laser diodes for the image projection.(They work with 3V. Keep the Old battery connector.
But wen need to replace the LED Diodes. The plan is to replace them with a new SK6812 RGB LED.
