The Pi64 is a Raspberry Pi 400 that thinks it's a Commodore 64.
love the retro vibes that the Raspberry Pi 400 gives off. The all-in-one computer-in-a-keyboard design makes me feel like I'm working with a computer from my childhood. The only problem I have is that when I look up from the keyboard, it's just another modern(-ish) computer running Linux. I set out to fix that with the Pi64.
Inspired by the Commodore 64, the Pi64 boots into a C64-themed bash shell in text mode. No X Server is involved. It is not a C64 emulator, it is Raspberry Pi OS, so you can get real work done; it just extends the Pi 400's retro feel to the screen.
pi400
How It Works
The following assumes that you are running Raspberry Pi OS (although I expect that many Linux distributions would work). As a prerequisite, you'll need to install tmux, e.g.:
sudo apt-get install tmux
Then you'll need to append the following color codes to your ~/.bashrc file:
if [ "$TERM" = "linux" ]; then    echo -en "\e]P0483AAA" # DARK BLUE     echo -en "\e]P1867ADE" # LIGHT BLUE    echo -en "\e]P2867ADE" # LIGHT BLUE    echo -en "\e]P3867ADE" # LIGHT BLUE    echo -en "\e]P4867ADE" # LIGHT BLUE    echo -en "\e]P5867ADE" # LIGHT BLUE    echo -en "\e]P6867ADE" # LIGHT BLUE    echo -en "\e]P7867ADE" # LIGHT BLUE    echo -en "\e]P8867ADE" # LIGHT BLUE    echo -en "\e]P9867ADE" # LIGHT BLUE    echo -en "\e]PA867ADE" # LIGHT BLUE    echo -en "\e]PB867ADE" # LIGHT BLUE    echo -en "\e]PC867ADE" # LIGHT BLUE    echo -en "\e]PD867ADE" # LIGHT BLUE    echo -en "\e]PE867ADE" # LIGHT BLUE    echo -en "\e]PF867ADE" # LIGHT BLUE    clear
fi
This replaces the standard tty colors with the RGB values for C64 light and dark blue. Next, to set the login banner, append the following to ~/.bashrc:
mem_total=$(cat /proc/meminfo | grep "MemTotal" | tr -s ' ' | cut -d" " -f2)
mem_total_unit=$(cat /proc/meminfo | grep "MemTotal" | tr -s ' ' | cut -d" " -f3)
mem_free=$(cat /proc/meminfo | grep "MemFree" | tr -s ' ' | cut -d" " -f2)
mem_free_unit=$(cat /proc/meminfo | grep "MemFree" | tr -s ' ' | cut -d" " -f3)
mem_total_unit=${mem_total_unit^^}
mem_free_unit=${mem_free_unit^^}
center() {  termwidth=224  padding="$(printf '%0.1s' ' '{1..500})"  printf '%*.*s %s %*.*s\n' 0 "$(((termwidth-2-${#1})/2))" "$padding" "$1" 0 "$(((termwidth-1-${#1})/2))" "$padding"
center "**** PI64 RASPBERRY PI OS ****"
echo ""
center "$mem_total $mem_total_unit RAM SYSTEM  $mem_free $mem_free_unit FREE"
echo ""
echo "READY."
echo ""
With that one-time setup in place, the Pi64 prompt can be launched by running the script:
./pi64.sh
It isn't super easy to get a tty to do this sort of thing, so it took a hacky sort of hack to get it working. A highly-tweaked tmux session is created (see tmux.sh), with 7 panes laid out something like this:
--       p0       --
-- p1 -- p2 -- p3 --
-- p4 -- p5 -- p6 --
Pane p2 in the center is the active display area, so a bash prompt is started there, and it is set as the active pane. All of the other panes run a bash script that hides the prompt and makes them look like a solid border, in C64 light blue. Borders between tmux panes are styled, and the status bar removed, to complete the effect.
The end result is pretty fantastic, if I do say so myself. It looks and feels like working on a C64, but with all the conveniences of a modern Linux distribution.
Media
YouTube:
After login: login
Running htop: htop
Running miscellaneous commands: misc
Raspberry Pi 400: pi400
Bill of Materials
1 x Raspberry Pi 400
About the Author
Nick A. Bild, MS
