Step 4. ECHO DOT & ESP32-WROOM-32, part 1
A project log for UV Sanitizing Autonomous Robot
Cost-effective robotic solution for surface sanitization in home
guillermo-perez-guillenGuillermo Perez Guillen 08/25/2021 at 17:480 Comments
Alexa Echo Dot                              Alexa Echo Dot
Echo Dot is a smart speaker that is controlled by voice and connects you to Alexa via Wi-Fi network. Alexa can play music, answer questions, tell the news, and check the weather forecast, set alarms, control compatible Smart Home devices, and much more.
ESP32-WROOM-32 Pinout
ESP32-WROOM-32 is a powerful, generic Wi-Fi+BT+BLE MCU module that targets a wide variety of applications, ranging from low-power sensor networks to the most demanding tasks, such as voice encoding, music streaming and MP3 decoding. Datasheet: https://circuits4you.com/wp-content/uploads/2018/12/esp32-wroom-32_datasheet_en.pdf
Alexa's voice commands:
How does it work?
To control your ESP32 with Amazon Echo, you need to install the FauxmoESP library. This library emulates a Belkin Wemo device, allowing you to control your ESP32 using this protocol. This way, the Echo Dot instantly recognizes the device, after uploading the code, without any extra skills or third party services.
Prerequisites: Installing the FauxmoESP Library
