What can I do with just the 3W LEDs?
A project log for Bullet Movies
Using red, green, and blue LEDs to capture short movies of very fast objects
ted-yapoTed Yapo 11/18/2016 at 02:220 Comments
So, I started thinking ... I used 1 second exposures (G, B, anyway) for the original still dice images. To get the correct exposure, I had to set the camera to ISO 100 and the lens to f/22. The ISO will go up to 3200, and the lens opens to f/1.8 (I cannot justify buying the very nice Canon f/1.4 or the coveted f/1.2). At these settings, the camera is:
times as sensitive. I should be able to use 210 us flashes and get the same exposure! That should be fast enough to capture the dice in motion, even using lousy 1-chip 3W LEDs driven with a BJT and a resistor.
I have to get down to the bench now.
I think I can make a simple trigger with two pieces of aluminum foil that get pressed together by falling dice.
