VinyGo, a stereo vinyl recorder
For artists, vinyl stores, recording studios, or music lovers
Public Chat
Music has accompanied men across the time, and artists transmit messages or emotions through their music. Studies show that music gives us motivation and pleasure. Promotes memory and helps to make sports. Reduces stress, anxiety, and pain. An enjoyable support to listen to music is the vinyl. Because the object is real, it has defaults, and it gives us the possibility to arrange a space to oneself in our house. Handling a vinyl, it's a true moment of happiness.
The goal of this project is to refresh the gramophone concept to build a vinyl recorder, easier, more accessible, and affordable. Is made for artists, vinyl stores, recording studios, DJs, or music lovers. Lot of music bands mistakenly think that a custom vinyl is expensive or is only for big music productions. VinyGo project will show you that you can create your own vinyl easily for less than 4 dollars/vinyl.
Logs section summary:
Functional diagram
Electronic
The PCB
Mechanic V1
Mechanic V2
Software
Flash LCD Nextion
Flash and build ESP32
List and cost of components
Getting started and functioning
1) Overview
1.1) Opportunity for vinyl recorders
Currently, vinyl disc industry facing to a shortage of polymers. This is due to the fire at the Apollo Masters factory and the covid-19 sanitary crisis. Order delays are very long and the prices have increased about 30% to 40% for industrial vinyl pressing. This leads to an almost impossible access to the small customer because the biggest customers are delivered before. It is therefore the small groups of music which have difficulty in making their own small series of vinyls. Vinyl recorders can solve this problem and make album creation accessible to small music bands (20 or 50 copies).
1.2) What vinyGo offers
Refresh old-fashioned vinyl technology by creating your own vinyls for:
  • DJs: Preparing your mixes on vinyl before your party,
  • Artists and music bands: Record your album on vinyl for you and your family,
  • Vinyl stores and small recording studios: Offers a vinyl engraving service to your customers,
  • Music lovers: Your favorite song does not exist on vinyl so create it.
1.3) How a vinyl recorder works
Burn sound on a matrix (vinyl)
It is the engraving of the audio signal by microgrooves on a matrix. Sound recording is in real time. A diamond, connected to two speakers (for stereo), vibrates above the blank lacquer which turns at 33 or 45 turns. The vibration is made by the speaker when the audio signal is played. This means that a groove is the exact representation of the speaker membrane vibration.
Mastering & Cutting
Before cutting the vinyl you have to apply some equalization like an iRIAA to the audio file. For the “cutting” you need to use a specific engraving diamond with an angle of 90 °.
1.4) Video
Note: The video sound is the sound of vinyl!
Sound extract "eye of the tiger" less than 20sec to respect copyright, and show the sound quality:
The proof:
2) Sagittal diagram
2.1) Description of the links
Note: VinyGo sound mastering can be done by software or by an extended board. Use L4 link if you use sound mastering by software or L2/L3 if you use a VinyGo sound mastering board. In this project presentation we use sound mastering software.
2.1.1) User
L1/L1’ :
  • Select a playlist of music on your media player
  • Configure the sound mastering
  • Configure the MIDI commands of your media player for the start, middle, and end groove
L6/L6’ :
  • Input/output to use the test mode
  • Input/output to use the calibration mode
  • Input/output to use the configuration mode
  • Input/output to use the update mode
  • Input/output to use the manual mode for the cutting vinyl
  • Input/output to use the automatic mode for the cutting vinyl
L11 :
  • Power on/off the vacuum cleaner
L12 :
  • Turntable configuration (33, 45, 78TRM)
L13 :
  • Adjust the sound volume
2.1.2) Media player
L1/L1’ :
  • Inform the user of the playlist select
  • Inform the user of the MIDI commands select
  • Inform the configuration of the sound mastering
L2 :
  • Useless (see note above)
L7/L7’ :
  • Allows to send MIDI commands to the vinyGo controller to automatically change parameters (like speed motor).
L4 :
  • Sound signal with mastering
2.1.3) ViniGo system
2.1.3.1) ViniGo controller
L6/L6’ :
  • Inform the user of the current mode
  • Inform the user of detected errors
  • Depending on the mode, inform the user of the recorder time, position of the engraving head, diamond heating, state of the sensors, ...
L7/L7’ :
  • Send MIDI commands to the media player
L9/L9’ :
  • Get the information of the sensors
  • Raising and lowering the head automatically
2.1.3.2) ViniGo sound mastering
L2 :
  • Sound signal without mastering (useless, see note above)
L3 :
  • Sound signal with mastering...
hrcSilver (1).zip
x-zip-compressed - 295.72 kB - 01/24/2023 at 20:31
Download
hrcNextion.zip
x-zip-compressed - 233.64 kB - 01/20/2023 at 15:25
Download
VinyGo.zip
In this zip file: All 3D files. all hardware files.t the full code for the WROOM32 MCU module and LCD, tools for the project.
Zip Archive - 38.92 MB - 08/29/2021 at 20:30
Download
  • 20 × Worm (M4)
  • 1 × Worm chicago (5mm)
  • 2 × Tweeter 120 Watt minimum
  • 1 × Strong glue (epoxy)
  • 1 × Lacquer cutting diamond
View all 14 components
  • Buy or win vinygo
    mras2an10/26/2024 at 07:00 2 comments
    Hello, vinygo lover,
    Is there anyone interested if I build and sell vinygo simplify electronic boards?
    if yes do not hesitate to answer in the comments "yes" and tell me in where you from.
    If many of you respond, I will launch a competition to win a vinygo simplify electronic boards.
    have a nice day
  • ​ Some news!
    mras2an10/09/2021 at 09:52 0 comments
    Currently, three peoples are use the VinyGo board on their own vinyl recorder.
    On top of that, one company has adapted its vinyl recorder to use it with the VinyGo board.
    Two people from the Hackaday community started building all the VinyGo system. I am looking forward to see photos. One of them found a synthetic diamond manufacturing company for vinyl recorders. The costs of the synthetic diamond is about $ 12 instead of $ 100 (but we have to rework it). However, this is revolutionizing and makes the price of the VinyGo system cheaper.
    A friend of mine has also started to build VinyGo system.
  • 11) Getting started and functioning
    mras2an08/29/2021 at 20:14 1 comment
    You have to clone VinyGo git repository: git clone https://github.com/Mras2an/VinyGo.git
    11.1) Hardware connection
    11.2) Compile and program the code
    See log 9) Flash and build ESP32
    11.3) First boot
    1 - Power on the VinyGo board, You see the LCD test menu.
    2 - Click on it, and check all the tests (sensors, and commands). If it OK return to the menu
    3 - Go to the calibration menu and make your calibration for 7, 10, and 12p vinyl.
    4 - The system is ready, enjoy :-)
  • 10) List and cost of components
    mras2an08/29/2021 at 19:49 0 comments
    PC
    ~ 200 $
    Turntable (you have to use direct drive whit high torque and not belt drive)
    ~ 250 $
    Mix table
    ~ 50 $
    Ampli
    ~ 50 $
    PreAmpli
    ~ 50 $
    VinyGo board with motors, sensors and LCD
    ~ 117,37 $
    VinyGo mechanic with diamond and 120W audio tweeters (if you have 3D printer)
    ~ 230 $
    Cables (RCA, MIDI, Jack)
    ~ 30 $
    Total
    977,37 $
  • 9) Flash and build ESP32
    mras2an08/29/2021 at 19:44 0 comments
      Cf tuto: Get Started esp32 — ESP-IDF Programming Guide latest documentation
    9.1) On GNU/Linux
    $ cd VinyGo/03_Software/ESP32/
    $ export IDF_PATH=$PATH/esp-idf/
    $ export PATH="$PATH:$HOME/Project/esp32/xtensa-esp32-elf/bin"
    $ make
    9.2) Flash ESP32
    9.2.1) On GNU/Linux
    link on binaries: https://github.com/Mras2an/VinyGo/tree/master/03_Software/ESP32/build
    $ python esptool.py --chip esp32 --port /dev/ttyUSB0 --baud 115200 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 $PATH/bootloader.bin 0x10000 $PATH/VinyGo.bin 0x8000 $PATH/customPart.bin
    9.2.2) Via Wifi (only if you have already done 9.2.1)
    ( https://www.python.org/downloads/release/python-2712/ )
    • Click on update in the VinyGo update menu (lcd).
    • Connect your PC at wifi “HRC” password “HRC2yBqT”
    On your PC execute the commands:
    GNU/Linux
    $ python  $PATH/update_firmware.py 192.168.52.1 $PATH/VinyGo.bin
    Windows
    C:\Users\Desktop\VinyGo>py update_firmware.py 192.168.52.1 VinyGo.bin
    or
    C:\Users\Desktop\VinyGo>python update_firmware.py 192.168.52.1 VinyGo.bin
    connecting to 192.168.52.1...
    connected, socket = <socket._socketobject object at 0x02582EA0>
    sending 'start OTA' command to target...
    sending fragment 1 of 125 (4096 bytes)
  • 8) Flash LCD Nextion
    mras2an08/29/2021 at 19:37 0 comments
    - Open project with Nextion editor (link: https://github.com/Mras2an/VinyGo/tree/master/03_Software/LCD_Nextion)
    - Connect the USB/RS232 cable at PC and on Nextion LCD (Rx, Tx, GND)
    - In Nextion editor click on Update
  • 7) Software
    mras2an08/29/2021 at 19:32 2 comments
    There are two micro-controllers on VinyGo. The master uses an ESP32, and the slave uses a stm32 for the HMI on the LCD touchpad. Both communicate via an UART protocol.
    It can be downloaded on the VinyGo git project. https://github.com/Mras2an/VinyGo/tree/master/03_Software
    7.1) UART protocol
    I created an UART protocol for the slave and master communication. Each frame is made as follows:
    Frame example to enter in system mode: 0x55 42 53 06 53 79 73 74 65 6d 54
    Start byte
    Header byte
    Command byte
    Data size
    Data
    End byte
    0x55
    0x42
    0x53
    0x06
    0x53 0x79 0x73 0x74 0x65 0x6d
    0x54
    7.2) IHM on LCD touchpad
    I chose a Nextion LCD touchpad and Nextion editor v0.53. With this LCD screen, we can design an HMI simply with drag and drop. Each text and button uses the UART protocol seen above.
    7.2.1) Manual mode
    With the manual mode we can adjust all the parameters of the burner one by one, like motor speed, stylus heating.
    7.2.2) Automatic mode
    With the automatic mode we just need to choose the vinyl size (7", 10", 12") and the time of your playlist. After that all is made automatically. The MIDI commands received in this mode increase or decrease the motor to create the start, middle, and end groove on the vinyl.
    7.2.3) Test mode
    If you have operating issues this mode is for you. You can test all sensors and commands.
    7.2.4) Update mode
    Very useful to send an update on VinyGo by OTA. VinyGo create its own AP, once connected to it you can send new software with a python tool (https://github.com/Mras2an/VinyGo/tree/master/03_Software/Utils)
    7.2.5) System mode
    System information like RAM, AP, ...
    7.2.6) Calibration mode
    VinyGo board is designed for several mechanics, so if you have your own mechanic you can use this mode to define the start of a 12, 10 or 7p vinyl.
    7.3) Master
    7.3.1) WROOM-32 module
    I chose the Wi-fi WROOM-32 module because this module has a nice memory capacity, a simple and complete SDK with a lot of examples. It is also very practical to update the binary by OTA to avoid having to connect wires during the development phase.
    7.3.2) SDK-IDF
    I chose SDK-IDF on the v3.1 branch. The SDK-IDF has a lot of contributors. It is available on github: https://github.com/espressif/esp-idf.git
    7.3.3) Flash partition
    To allow the update of the system via the wifi we need more partitions. Espressif proposes the possibility to create a cvs file to define the addresses. Here is the one of the VinyGo:
    # Name, Type, SubType, Offset, Size, Flags
    otadata,data,ota,0xd000,8K,
    phy_init,data,phy,0xf000,4K,
    factory,app,factory,0x10000,1M,
    ota_0,app,ota_0,0x110000,1M,
    ota_1,app,ota_1,0x210000,1M,
    nvs,data,nvs,0x315000,500K,
    So we have a partitioned memory as follows:
    |   Addr       |   Binaries
    | 0x001000 |  Bootloader.bin
    | 0x008000 |  Partitions.bin
    | 0x010000 |  Factory.bin
    | 0x110000 |  OTA_0.bin
    | 0x210000 |  OTA_1.bin
    | 0x315000 |  NVS (500Ko)
    | 0x3F0000 |  Free
    7.3.4) The architecture
    7.3.4.1) The Espressif SDK
    The SDK used is the SDK-IDF on the v3.1 branch available on github at (https://github.com/espressif/esp-idf). This is the official development system of the ESP32 chip.
    7.3.4.2) The drivers
    Used for different hardware interactions such as motors, or the functionality of the WROOM32 module (Gpio, wifi, OTA, UART, PWM, ...).
    7.3.4.3) The HAL and OSAL
    HAL and OSAL allow simple porting of VinyGo to another SDK, OS, or hardware platform.
    7.3.4.4) The application...
  • 6) Mechanic V2
    mras2an08/29/2021 at 19:26 0 comments
     All these STL files can be downloaded on the VinyGo git project. https://github.com/Mras2an/VinyGo/tree/master/01_3D%20Modeling
    This mechanic is in the testing phase, this is why I am not presenting it at the 2021 Hackaday price. It just to show that the project is evolving for a better version. it is optimized to reduce the number of 3D parts.
  • 6) Mechanic V1
    mras2an08/29/2021 at 19:23 0 comments
     This mechanic works well, it is a proof of concept but we have lot of small 3D pieces to print.
    6.1) Structure
    6.1.1) Standard mechanical pieces
    Standard pieces for the structure can be purchased on the internet, here is the list:
    • Profiled aluminum 40x4cm
    • Worm screw 50cm, (diameter : 8mm)
    • Ball bearings
    • Steel rod 50cm, (diameter : 8mm)
    • Worm (M4)
    6.1.2) 3D pieces example
    6.2) Head
    6.2.1) Standard mechanical pieces
    Standard pieces for the head can be purchased on the internet, here is the list:
    • Worm chicago (5mm)
    • Worm (M4)
    • Tweeter 120 Watt minimum
    • Strong glue (epoxy)
    • Lacquer cutting diamond
    • Spring
    6.2.2) 3D pieces example
    6.3) Stylus
    This is the most expensive part, because we need a cutting “diamond”. It can be purchased on the internet for more than 100$. For a cost reduction, some people use Roland blades, around 5$ but it is not the same sound quality.
    Diamond
    Roland blade
  • 5) The PCB
    mras2an08/29/2021 at 19:06 0 comments
    All schemas and PCB (gerber), can be downloaded on the VinyGo git project. https://github.com/Mras2an/VinyGo/tree/master/02_Hardware
    The PCB does not have any particular constraint except to respect the "hardware design" proposed by Expressif to have the best radio performances. “make sure that the module is not covered by any metal shell. The antenna area of the module and the area 15 mm outside the antenna should be kept clean”.
    5.1) PCB components list (Price in $)
    The BOM can be found here: https://github.com/Mras2an/VinyGo/tree/master/02_Hardware
View all 12 project logs
  • 1
    Assembly left side
  • 2
    Assembly right side
  • 3
    Assembly for version 1
View all 7 instructions
djsopaul wrote 11/10/2024 at 04:50 point
has anyone figure out ESP32 flashing yet?
Olivier wrote 02/22/2023 at 18:23 point
Hello I'm looking to buy a machine do you know where I can find a complete one?
Thank you Olivier
hbanko wrote 01/22/2023 at 03:16 point
I have built the PCB and got all parts but I am stuck and not hearing back from the author. It would be really helpful to have some clear instructions how the ESP32 flashing works. Thats where I am stuck. On the P4 header, what is RX and TX? Is ground on the bottom of the circuit board or inside? The boot jumper is supposed be on or off? The reset jumper should be off? It would just help to have the "exact" information to take out the guessing. What is a good indicatior that flash was successfull? That the "HRC" access point would instantly show up after powering up?
mras2an wrote 01/24/2023 at 20:39 point
do not hesitate to comment on things that are not clear, this may help others... for the ESP, the explanation of the flashing is in the datasheet. you have to put the jumper and power the card then flash. once finished turn off the power, remove the jumper and power the card. if you watch on a terminal at 115200 baud you must have logs
lemonjy554 wrote 01/04/2024 at 07:26 point
Can you give me a complete BOM list please
hbanko wrote 01/22/2023 at 03:09 point
A cool project, but unfortunately the docmentation has a lot of gaps. That just makes it really hard to troubleshoot if things are not going according to plan.
mras2an wrote 01/24/2023 at 20:42 point
The project is not easy to build I agree, there are more than 40 pages of explanation and it would take twice that. feel free to comment on things that are not clear, it may help others...
LeeQC23 wrote 01/18/2023 at 21:46 point
Hi !
Any details and informations on the sourcing of sapphire / diamond for lathe cutting ? Searched a lot on the web, just found one source from the T560 vinyl recorder...
Thanks !
zokensginsing747 wrote 01/17/2023 at 15:05 point
Ganbaa wrote 01/12/2023 at 14:39 point
Hello I am happy to say that this is a really cool project.
We are trying to do this project but There is an error “Damaged”on the LCD display program. Can you send the file of the program through email or re-upload it somehow? Thank you
mras2an wrote 01/16/2023 at 15:42 point
hello what danage do you have? I dont have it. Do you try to flash the lcd with sdcard ?
Ganbaa wrote 01/17/2023 at 14:30 point
Nextion editor can't open hrcNextion.HMI file. When I open hrcNextion.HMI file "Wrong resource file or resource file has been damaged" popup shows on Nextion editor.
Plse chek pm sent you pic
mras2an wrote 01/18/2023 at 08:01 point
I think you dont use the same nextion version as me... (v0.53). Use this version or try with sdcard
Nick wrote 01/10/2023 at 13:07 point
Hello. I’d really like to begin building this project ASAP. I’ve tried to have the PCB assembled, but they are having trouble identifying about 10 parts on the BOM, mainly the capacitors. For example, what is 47u on this BOM? Is there anyone who can help me identify these parts? Thank you.
lemonjy554 wrote 01/04/2024 at 07:27 point
Have you solved this problem?
FORART fe wrote 12/01/2022 at 19:15 point
Hi there, this is a very fun and interesting project !!
Suggestion: what about LASER cut ?
Check out this MVVBlog video to get an idea: https://www.youtube.com/watch?v=nazpxrtvpoM
Hope that inspires !
Woxoshd wrote 09/16/2022 at 11:22 point
Hi everyone, i did not found the références of the différents sensors in the bom, anybody know what are they?
Same for the heater, i cant find a reference.
My pcb and mechanic are ready but incomplete...
lkrizane wrote 10/22/2022 at 21:03 point
I think that sensors are standard hall sensors and limit switches like on 3d printers (see links). I`m also making VinyGo and many thing are unclear. I`ve made electronics and testing is in progress. Mechanics will be finished in near future. If you find heater and link for needle please post here. Thanks !
https://www.aliexpress.com/item/32663114987.html?spm=a2g0o.productlist.0.0.6aca17eajdhBy8&algo_pvid=7e62e760-cadf-4037-b01c-4596eccdc5d9&algo_exp_id=7e62e760-cadf-4037-b01c-4596eccdc5d9-49&pdp_ext_f=%7B%22sku_id%22%3A%2259987436864%22%7D&pdp_npi=2%40dis%21USD%212.61%212.45%21%21%210.26%21%21%402101e9d516664717498558878e87e2%2159987436864%21sea&curPageLogUid=wfsOf3hl5PD1
https://www.aliexpress.com/item/32273125391.html?spm=a2g0o.productlist.0.0.56335cd260SfbT&algo_pvid=a7697e7a-bc00-413a-8683-8a8b6a43a367&aem_p4p_detail=202210221400412596094046164880002765455&algo_exp_id=a7697e7a-bc00-413a-8683-8a8b6a43a367-0&pdp_ext_f=%7B%22sku_id%22%3A%2212000024479250586%22%7D&pdp_npi=2%40dis%21USD%210.64%210.59%21%21%211.06%21%21%40210318c916664724414868842e6f16%2112000024479250586%21sea&curPageLogUid=wCgVWBlVZQiU&ad_pvid=202210221400412596094046164880002765455_1
Cedric wrote 11/28/2022 at 20:55 point
Hi ! Trying to figuring out all parts and references of the BOM. but I miss a lot of infos. Like what kind of capacitor 47u or 10u stands for.  Someone that already built a pcb + components could share his BOM with suppliers and references please ?
lkrizane wrote 08/27/2022 at 06:33 point
Anybody can help me with drill files ? I cant export them to GCODE file. Anybody has it converted ? Maybe Top + bottom layer + drills in GCODE ? Thanks
HoocH wrote 05/02/2022 at 17:14 point
hello i like buy an full assembly vinygo control box ???
inm247 wrote 04/12/2022 at 00:40 point
Can anyone please share what or where to get
Worm (M4)
Worm chicago (5mm)
Want to be sure I'm getting the right part before i go and buy 20
mras2an wrote 04/12/2022 at 08:38 point
for worms M4: https://www.amazon.fr/Foliv-Hexagonale-Inoxydable-Ext%C3%A9rieur-Assortiment/dp/B09QSM5PVM/ref=mp_s_a_1_1_sspa?crid=3Q2RX4MGT0X1T&keywords=vis+m4&qid=1649752500&sprefix=vis+M4%2Caps%2C278&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFFQ0c5VlpNMldEQjgmZW5jcnlwdGVkSWQ9QTEwMzAzMDU5RU9KWUoxWVg0WkkmZW5jcnlwdGVkQWRJZD1BMDMyMTY1N1EyNFk3VktRTjU3MyZ3aWRnZXROYW1lPXNwX3Bob25lX3NlYXJjaF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
For Chicago is useless for V1 meca
inm247 wrote 04/13/2022 at 01:35 point
Thank you very much mras2an.
Regarding the spring what size, diameter should it be?
solidbond74 wrote 04/06/2022 at 14:26 point
I know that you suggest 120 watts minimum, but what is the tweeter diameter to fit the V1?
ansurdu wrote 04/06/2022 at 20:31 point
I asked earlier and they directed me to these For tweeters: https://www.amazon.fr/gp/product/B005S553TK/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I've also combined this and another project into a new cutter head that uses these contact sound drivers: https://www.amazon.com/gp/product/B0066AYMTS/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I modified it to screw on to mras2an's lathe design that I'm currently figuring out. dm me if interested. if you have any ideas on how to set up the sensors properly, I'm about a month away from powering up the board and feel like I'm missing something
mras2an wrote 04/07/2022 at 20:05 point
hello what do you mean by "how to set up the sensors properly". You just need to connect it to the board (on the good input).
mras2an wrote 04/07/2022 at 20:10 point
when all sensors are connected Powering the system and go to test mode whit the LCD.  Check on the graph if all sensors state switch.
solidbond74 wrote 04/02/2022 at 18:31 point
How much counterweight do we add?
mras2an wrote 04/03/2022 at 12:26 point
about 200g
ansurdu wrote 03/12/2022 at 16:12 point
I'm getting into setting up my cutting head and I'm wondering what amplifier/tweeter combos everyone is using and how they're rigging everything. I bought some super bullets like in the diagrams but they're obviously not the ones used in the prototype.
Tacking onto my earlier comment, I'm looking for guidance on what specific sensors you're using and how you're setting them up to get the proper data inputs.
ansurdu wrote 03/27/2022 at 00:05 point
Hello again! I feel like a bother, but I'm figuring out this thing unless something kills me. I'm still curious about how these hall sensors are set up.
What is the significance of the copper sheeting and wiring connected to the counterbalance
mras2an wrote 03/30/2022 at 13:15 point
Hello, sorry for delay
I don't understand your question about hall sensors configuration. It is a basic on/off sensor
For "the copper sheeting and wiring connected to the counterbalance" it is just to detect if the head is up or down
inm247 wrote 01/20/2022 at 20:17 point
Hello mras2an,
I wonder if i could get your help please when you have a spare moment.I have found a company to make and assemble the PCB for me but i need some extra information to get my order going,
1. How many layers do i need? i have a choice of 1, 2, 4, 6, 8, 10 or 12 layers (or does it not matter?)
2. What Copper weight (or does it not matter?)I have a choice of 35, 70 or 105 microns
3. Thickness? (or does it not matter?)I have a choice of 0.5, 0.8, 1.0, 1.2, 1.6, 2.4 or 3.2mm
4. Finish? (or does it not matter?)I have a choice of IS or ENIG 5. What is the Circuit Size X/Y in mm?
For reference: https://www.pcbtrain.co.uk/services/pcb-fabrication-assembly
sunny wrote 03/13/2022 at 16:16 point
1 look the gbr file   2, 1.6OZ or 1.0OZ    3,1.6MM   4 I don't know
inm247 wrote 04/12/2022 at 00:37 point
Thank you very much.
inm247 wrote 01/18/2022 at 22:02 point
Is it possible to buy assembled PCB boards for this project ?
salihboz wrote 03/04/2022 at 17:31 point
yes, im wondering that too..
ansurdu wrote 03/12/2022 at 16:08 point
I'm in the process of building my first and ordered mine through jclpcb.com and they were only able to do minimal assembly. i do plan on putting these together and selling kits in the future. It's been a real process to find everything
Red_Delta wrote 11/17/2021 at 17:01 point
Hello, I just wanted to say that this project is amazing and I am anxiously awaiting the updated head. I did have have one question regarding disc blanks, have you only cut polycarbonate blanks or have you tried alternative materials like PETG?
mras2an wrote 11/22/2021 at 12:14 point
hello i only test PVC blank disc
sebastian.minkewitz wrote 11/01/2021 at 13:12 point
Amazing work. thanks a lot for bring this online. Such a project I`m searching for a long time so I will join this journey and want to build this by my self. (incl. the hardest part for me with the pcb - I don't have experience in this..) I have read all logs, the manual and all what I can find here, I ordered the first parts now and my Prusa Printer run with the V2 mechanics. there are first questions about some missing informations on your documentation. Can you tell me what type of step motor and servo motor you use? are there coming some detail infos on assembly the cutterhead? and what is on the image about the cutterhead for a sensor? (the blue one) .. ah and is this the right place for communicate about this project?
mras2an wrote 11/01/2021 at 16:07 point
hello, thank you for your comment and your questions, it's always nice to see that people are interested by vinyl recorders. Please note that the V2 mechanic is not released, it is still in testing phase. So it will evolve according to this ... for the step motor I use 1.5 A 2.4V 1.8 ° 420mN.m (standard for CNC) and for the servo motor I use SG90 on the V2. I will add these information on the BOM post.
"are there coming some detail infos on assembly the cutterhead?", At this time, unfortunately I no longer have head and twitter to take pictures of the head assembly.
"what is on the image about the cutterhead for a sensor? (the blue one)" are you talking about the blue on the diamond? If so, it is the heating wire to heat the diamond.
sebastian.minkewitz wrote 11/01/2021 at 16:26 point
ah ok, thanks for the information.  And no I don’t talk about the heatwire, but I think I solved the question, it’s the servomotor - on the build image it is black and the preview picture where to go with, it is in a blue housing.
Damn I think v2 is ready - ok then I have to print some more parts 🤷🏻♂️  And some more question: what sensor is used as head and trey?
So I think I let some time go wait for the ordered parts and after starting with the assembly with new questions I will call you here again.  😉
mras2an wrote 11/01/2021 at 17:41 point
indeed the servo motor is not the same between V1 and V2. on V2 it is cheaper. I will keep you posted when the V2 will be release. But I still have a lot of work to do because I would like it to be smaller and integrate the sensors into 3D (to simplify the manufacturing).
sebastian.minkewitz wrote 11/01/2021 at 22:16 point
what motor type is on v1?
mras2an wrote 11/02/2021 at 11:16 point
Ok, I added all ref information on the BOM file on github. Thank you for your comments.
