Hardware CHUMP
CHUMP stands for "Cheap Homebrew Understandable Minimal Processor".
It is the invention of Dave Feinberg and described in his paper "A Simple and Affordable TTL Processor for the Classroom".
I am not a fan of Control ROMs for simple computers. So this project looks at a hardware control version of CHUMP.
Original CHUMP Instruction Set
The original CHUMP had the following instructions:
OpCode Instruction Comments
0000 LOAD const ACC = CONST;
PC++;
0001 LOAD mem ACC = MEM[ADDR];
PC++;
0010 ADD const ACC = ACC PLUS CONST;
PC++;
0011 ADD mem ACC = ACC PLUS MEM[ADDR];
PC++;
0100 SUBTRACT const ACC = ACC PLUS CONST;
PC++;
0101 SUBTRACT mem ACC = ACC PLUS MEM[ADDR];
PC++;
0110 STORETO const MEM[ADDR] = ACC;
PC++;
0111 STORETO mem MEM[MEM[ADDR]] = ACC;
PC++;
1000 READ const ADDR = CONST;
PC++;
1001 READ mem ADDR = MEM[ADDR];
PC++;
1010 GOTO const PC=CONST;
1011 GOTO mem PC=MEM[ADDR];
1100 IFZERO const IF (ACC==ZERO) THEN PC=CONST
ELSE PC++;
1101 IFZERO mem IF (ACC==ZERO) THEN PC=MEM[ADDR]
ELSE PC++;
The Original CHUMP Data Flow Diagram
Here is the Original CHUMP data flow diagram:
Harvard Architecture
CHUMP uses the Harvard Architecture which means the program is in Read Only Memory (ROM) and data is in Random Access Memory (RAM). It is not possible for CHUMP to self program. All programs must be written to an Erasable Programmable ROM (EPROM).
Extended Instruction Set
To reduce the hardware logic complexity I have reworked the instruction set:
0000 ADD const ACC = ACC PLUS CONST
0001 ADD mem ACC = ACC PLUS MEM[ADDR]
0010 LOAD const ACC = CONST
0011 LOAD mem ACC = MEM[ADDR]
0100 NAND const ACC = ACC NAND CONST
0101 NAND mem ACC = ACC NAND MEM[ADDR]
0110 XOR const ACC = ACC XOR CONST
0111 XOR mem ACC = ACC XOR MEM[ADDR]
1000 JNC const IF (!CARRY=HIGH) THEN PC=CONST
1001 JNC mem IF (!CARRY=HIGH) THEN PC=MEM[ADDR]
1010 STORE const MEM[ADDR] = ACC
1011 STORE mem MEM[MEM[ADDR]] = ACC
1100 READ const ADDR = CONST
1101 READ mem ADDR = MEM[ADDR]
1110 PAGE const PAGE = CONST
1111 PAGE mem PAGE = MEM[ADDR]
I have replaced SUBTRACT with NAND. NAND is necessary for bit operations such as AND and OR etc. I have added XOR as it takes too many instructions to generate it from NAND instructions.
Subtraction can be modeled as:
   SUB ? = NAND -1; ADD ?; NAND -1
I have added a PAGE instruction to extend the ROM capacity to 256 bytes. The PAGE register is preloaded but only sets the upper 4 bits of the program counter upon a jump.
I have replaced GOTO and IFZERO with JNC (Jump on Not Carry). The not carry and jump logic only works immediately following an ADD instruction. Otherwise the JNC is unconditional (i.e. always jumps).
The carry flag is necessary for double precision arithmetic and can replace the zero flag for loops and comparison operations with code modification.
Port Input and Output
There is no Input and Output (I/O) command at the moment. It is proposed to map I/O space over RAM space (say address 0x0F).
Upon review, I find I can use any memory reference instruction immediately after a STORE instruction to read an input port.
Control Logic
Here is my version of the control logic:
For the Hardware Control Logic, the following schematic was developed:
Special Behaviours
To get the required (special behaviours) logic for the JNC/ADD (!JUMP) and RAM write signal (!MWR), the follow logic was used:
The main problem was latching or delaying the action until the next clock cyle.
CHUMP V3 Hardware Schematic
Here is the schematic:
Final Comments
Final comments before implementation.
The clock is manual, each press cycle the CPU.
The schematic need to be reviewed before designing the PCB.
PCB
Here is the PCB:
Some Thoughs About The Original CHUMP Chip Count
Although the original CHUMP claims and shows images of 10 chips, in fact based on the recommended memory chip 74LS189/734LS289, I don't underand how. These recommended RAM chips invert the output, and without the output being re-inverted (i.e. with a 74LS04 etc.) the CPU should not work. I suspect the 10 chip version of CHUMP used the 74LS219 RAM chip (which does not have an inverted output).
There is some confusion in the 74LS181 datasheets with regard to the function output being inverted (based on some images), but the output is not inverted for positive logic, which is what we both use.
Anyway, let us say the original CHUMP needs a 74HC04 to reinvert the memory output.
Original CHUMP with 74LS219 chip is 10 chips:
I think the extra 6 chips is worth the improvement.
AlanX
