Version 4
A project log for CHUMP
CHUMP stands for Cheap Homebrew Understandable Minimal Processor. It is the invention of Dave Feinberg.
agpcooperagp.cooper 09/15/2021 at 23:470 Comments
Version 4
In version 4 I want to use a less aggressive memory write timing. Here is the updated Control logic:
Here I have done two things:
  1. The system clock (CLK2) is delayed 18ns behind the clock input (CLK1).
  2. The Memory WRite signal is ORed the clock input.
The results for the Memory WRite (!MWR) timing are:
  1. tAS (Address Setup time) is about half a clock cycle.
  2. tWR (Write Recovery time) is about 27 ns (before the rise of CLK2)
Replacing the 74LS189
Replacing the 74LS189 with a standard Static RAM (SRAM) such as a 6116.
This requires a modification to the ALU to make the output tri-state and to directly select the Port bus:
There is also a new ACCUM bus so that the Accumulator can be monitored regardless of the output state of the ACC bus.
Here is the updated Top Level Schematic:
Upgrading the Clock
I want to upgrade the Reset and Step with Run (clock) and Stop (clock). The logic should be Reset and Step should stop the clock:
Note: I have added power on reset.
Note: The 7414/Or mess is actually one gate of a 74HC132 (Schmitt Trigger).
AlanX
