11Step 11 - Perform balancing check
12Step 12 - Final check
Complete the BMS installation, checking all the functions and finding the correct settings for your application. I remind you that voltage and temperature thresholds parameters must be set according to cells specifications!
Here is a list of possible checks to be carried out:
- Check the correct setting of Current sensor comparing the value on display with the value measured by a DC current clamp
- Check the stop of charging and discharging enable and alarm on display in case of cell modules I2c disconnection or simulating a cell module loss by unplugging the J4-J5 7pins connectors
- Check temperature values and alarms heating the sensor by a hairdryer (be careful...of course)
- Follow all the charging steps, checking the correct behavior of the system and finding the best settings
- Check the stop of discharging enable, simulating a cells low voltage (for example you can modify the Low voltage parameters with a higher value)
13Step 13 - Enjoy Green BMS!
