Have you ever considered the possibility of reconditioning the batteries you have instead of throwing them away?
I'm going to assume that temperature is in Farenheit :)
It would have been cool, if you would have explained why the catalyzing action no longer works after 4 or 5 times. A more effective method actually is, an acetic acid (30 percent solution, sometimes 50 or 60%) added to each cell, because what is really going on, is oxidation build up on the zinc substrate, on the grid cells, that react with the sulfuric acid. The sulfuric acid can be re-purposed back into the battery cells.
Remove the oxidation, and you bring the cells back to life!
This does not recondition the battery, it is a stop gap method to get a little more life but that's about it.
Video has been removed..
