• A miniature mirror stereoscope is presented that provides high quality, affordable, dichoptic display inside the MRI-scanner
  • The visual properties of the dichoptic image are true to those of the MRI-back projection display screen
  • The MRI-stereoscope is adjustable and materials are readily available
  • It can be installed on the widely used Siemens 3T 64-channel head coil system with a back-projection
  • The manufacturing files are open-source, can be assembled using CAD software and modified
