Gotek flashed
A project log for Atari ST Floppy Drive Emulator Adapters
Connecting a floppy drive emulator (Gotek) to the Atari ST with a few small adapter boards.
Justin DavisJustin Davis 09/17/2021 at 20:000 Comments
I finally got the Gotek drive flashed with the FlashFloppy firmware: https://github.com/keirf/FlashFloppy
Unfortunately, I ordered the "wrong" board which requires the ST-Link to program it.  Fortunately, I happened to have an ST-Link here.  However, the drive is not quite working as planned.  I think since it's not a very supported board by the community, I may have something backwards.  Changing the jumper over to a different set of pins from what it recommended, the ST detects drive B and tries to read from it, but it comes up as garbage in the directory.
