Swallow is a compiled programming language currently under development.
Why am I creating this language?
I am creating it as a fast alternative to python and as an easy alternative to c
Goals
- Ease to use
- Fast
- Highly modular
- Occupies less memory
- Compiled
How does it work?
You can consider it to be a superset of c which compiles to clean c. So valid c code is also valid swallow code(the language is named swallow). It will have no garbage collector because it is a system programming language but it will be very easy to use so there will be less chance of memory leak
If you created a new programming language, then I will be shocked. I don’t understand at all how it can be created, how much work it takes. I recently wondered how to write software requirement specification for your project, I used https://ddi-dev.com/blog/programming/how-to-write-software-requirement-specification-for-your-project/ for this. My brain was literally exploding. Your IQ is probably just off the charts, I can’t explain it any other way. In any case, a like from me!
