Swallow is a compiled programming language currently under development.
Why am I creating this language?
I am creating it as a fast alternative to python and as an easy alternative to c
Goals
- Ease to use
- Fast
- Highly modular
- Occupies less memory
- Compiled
How does it work?
You can consider it to be a superset of c which compiles to clean c. So valid c code is also valid swallow code(the language is named swallow). It will have no garbage collector because it is a system programming language but it will be very easy to use so there will be less chance of memory leak
You can believe it to be a superset of c which gathers to clean c. So legitimate c code is likewise substantial swallow code the language is named swallow. Peruse this likewise A contentious essay is an enticing essay that utilizes contentions to guard a point. Each <a href="https://academiadeescrita.com/">href="https://academiadeescrita.com/</a> essay necessities to have a presentation with a snappy snare and a plainly composed guarantee.
