Breadboard prototype
A project log for MakeTime
Arduino-compatible development platform whose primary function is a clock
mihaicuciucmihai.cuciuc 10/12/2021 at 18:370 Comments
Don't feel like committing to getting PCBs made and then soldering a handful of SMD components? How about trying it out on a breadboard first? After all, this is how it all started.
You'll need:
 - 1x Arduino Nano
 - 1x DS3231 RTC module
 - 1x Addressable LED ring with 24 LEDs
 - 2x 10 kOhm resistors
 - 1x Pushbutton
 - 1x Light dependent resistor (LDR)
 - Breadboard, wires, soldering iron (for the LED ring as it doesn't come with anything connected to the pads)
Use the firmware from GitHub
Wiring diagram and a picture of what you can expect to get:
