Refer to microcode and source code.
This component has the following capabilities:
- Accept ASCII characters on its 8-bit write-only port with simple handshake logic (it can interface with an UART to accept serial stream from host computer)
- Interpret incoming character stream as records in Intel .hex file format
- If the record received is valid (no bad characters, right number of bytes, good checksum), write the record to memory
- Memory interface is 16-bit address, 8-bit data, and using DMA logic similar to Z80 (BUSREQ - BUSACK)
- Signals error on a dedicated pin
- Provides a debug serial port to trace execution of the internal microcode
zpekic
