CAN Extruder Board + PT100 500°C
A project log for CAN bus Reduce the wires of your 3D printers
Reduce the wires from more than 19 to only 4
markmark 12/07/2021 at 14:190 Comments
New version of CAN Extruder Board is now orderable, beside support normal thermistor temperature sensor, it has one more chip MAX31865 that can support PT100 temperature sensor(-30°C to 500°C)
