The Keyboard Encoder
A project log for Sol-20 Reproduction
I am making a full sized Sol-20 reproduction, the first fully assembled microcomputer with a built-in keyboard and television output.
michael-gardiMichael Gardi 10/21/2021 at 04:010 Comments
I talked about Dave's very flexible encoder in my previous log and in this one I'll cover it's construction.
I'm still waiting for the keyboard switches to arrive (last seen in Chicago IL), but the hardware for the encoder hit my mail box a couple of days ago. I followed Dave's assembly notes on GitHub. Here is what the end result looks like.
The assembly was all pretty straight forward. Nothing to see here. What was a little trickier was flashing the ATmega328P with the encoder firmware.  Dave uses Atmel Studio 7 to build the firmware and a high end Atmel-ICE programmer burn the chips. A little out of my price range.
Fortunately you can use practically any Arduino as an AVR programmer. There is a lot of sometimes confusing information online on how do do this. I'll just tell you about what worked for me.
I started by opening the Arduino IDE and loading the sketch ArduinoISP.
I had a Arduino UNO attached on COM12 so I compiled and uploaded ArduinoISP with the following settings.
Then I switched the Programmer: setting in the IDE to Arduino as ISP.
Using jumpers I wired the Arduino UNO to the encoder board's ISP Header with the following connections.
ArduinoISP Header
Pin 10 Pin 5 (RESET)
Pin 11Pin 4 (MOSI)
Pin 12Pin 1 (MISO)
Pin 13Pin 3 (SCK)
+5V+5V
GNDGND
Here is my setup.
The Arduino IDE uses a command line program called avrdude under the covers to flash AVR devices. Getting the command line parameters to this program correct can be tricky. Fortunately there is a GUI called avrdudess which can be found here that I downloaded.
I didn't have an environment setup to build Dave's encoder firmware, but he was kind enough to send me the latest build's HEX file. At this point I was all set to flash the ATmega328P on the board. I fired up avrdudess.
I altered the following inputs:
Then I pressed the Program! button. You can see that the writing and verification all checked out so the keyboard encoder is ready to go.
