BetterSerialPlotter-v0.1.0-Linux.tar.gz
Unzip the folder and then run the app. You need to run the app with sudo permission because it requires access to the serial port. Note that if you don't run it with sudo, it will still run, but serial ports won't open.
x-gzip -
1.57 MB -
09/17/2021 at 23:52
