Marblevator, Wheels, Vertical.
Using cones as opposed to cylinders in the marble wheels.
Public Chat
After publishing "Marblevator, Wheels", YouTube follower RobotHut (https://www.youtube.com/user/Robothut) commented regarding the use of "cones" in the wheels as opposed to "cylinders". By using cones, he explained, the model could remain vertical during operation as opposed to being tilted rearward, and the cone shape would provide the slope necessary to transfer the ball bearing from the front wheel, to the rear wheel, then to the base.
So here it is, "Marblevator, Wheels, Vertical" standing vertical and using cones in the wheels as opposed to cylinders. In the linked three part video, the cad model, assembly process and operation are shown.
Video is here: https://youtu.be/nVL4GOr3ff0
Greg Zumwalt wrote 09/15/2021 at 14:30 point
Thanks dearuserhron, I'm glad you liked it.  I'll check it out and would be glad to examine the links you provide!
Greg
dearuserhron wrote 09/14/2021 at 21:23 point
Nice toy. If you read this, you can try to reproduce Leonel Penrose's self assembling toys. I can give you original paper and point you to the youtube videos.
