Tested Firmware Version for SENSIRION SHT3X-DIS
Sensor probing requests.
0x44 Address "SHT3X-DFLT"
0x45 Address "SHT3X-ALT"
Power management for the LC-Display.
Display will be scrolled (11 digits).
HRD can be connected to external devices like personal computers to transfer and store the extracted technical data.
Similar project: Handheld Readout Device(HRD) for Battery Management Systems (8-bit commands)
https://github.com/peterloes/HRD
EXTENSION:
Next generation of Data Logger for varied range support of Sensors.
https://github.com/peterloes/Data_Logger
Code Snippets
Make quick changes to the Source Code.
 https://github.com/peterloes/HRD_SENSOR/blob/main/Software/main.c
    /*! List of items which can be displayed
     * This array contains a list of items that can be displayed on the LCD.
     * Element 0 is a special case, it shows the name, version, and date of
     * the firmware image.  Usually up/down push buttons are used to select
     * the item to be displayed.
     * The order of these items may be rearranged by the user.  Single or
     * groups of entries can be de-activated by commenting them out.
static const ITEM l_Item[] =
{  // [1234567890123456]    Cmd                                            Frmt
{ ">>> SHT3X-D <<<",          SBS_NONE,                                 FRMT_FW_VERSION  },
{ "Sensor at SMBus",           SBS_NONE,                                 FRMT_SENS_CTRL    },
{ "Supply Battery",               SBS_NONE,                                 FRMT_CR2032_BAT  },
{ "Soft Reset",                      SBS_SOFT_RESET,                     FRMT_HEX     },
{ "Serial Number",               SBS_READ_SERIAL_NUMBER,   FRMT_HEX    },
https://github.com/peterloes/HRD_SENSOR/blob/main/Software/drivers/SensorMon.c
/*!@brief Probe List of supported Sensor Controllers */
static const BC_INFO l_ProbeList[] =
{  //  addr    type        name (maximum 10 characters!)
    {  0x88,    BCT_SHT3X_DFLT,    "SHT3X-DFLT"    },  // 0x44 Address 7 MSBs 0x88
    {  0x8A,    BCT_SHT3X_ALT,    "SHT3X-ALT",    },  // 0x45 Address 7 MSBs 0x8A
    {  0x00,    BCT_UNKNOWN,    ""        }   // End of the list};
https://github.com/peterloes/HRD_SENSOR/blob/main/Software/drivers/SensorMon.h
/*!@brief SBS Commands
 * These are the defines for the registers of the sensor controller.  Each
 * define contains the following bit fields:
 * - Bit 26:24 specify the controller type where the define belongs to. Bit 24
 *   (0x1000000) represents the Sensor SHT3X-DFLT controller,
 *   while bit 25 (0x200000) specifies the Sensor SHT3X-ALT controller.
 *   If both bits are set (0x300000), the register exists in both controller
 *   types.  Bit 20 is used if no controller is connected to
 *   identify the remaining valid entries (where SBS_NONE is set).
 * - Bit 23:16 contains the number of bytes to read.  For 8, 16, or 32 bit values
 *   SensorRegReadValue() is called, while for more than 4 bytes function
 *   SensorRegReadBlock() will be used (block command).
 * - Bit 15:0 of the enum contains the address as used for the SBS commands sent
 *   via I2C.
 * All command sequences beginn with I²C device address to access the sensor
 * controller. The device address depends on the type of battery controller:
 * - 0x44 in case of SHT3XL, and
 * - 0x45 for the SHT3XH.
 * The address can be probed via SensorCtrlProbe().
 * @see
 * Functions SensorRegReadWord() and SensorRegReadBlock() use these enums.
 * A list of all registers can be found in document
 * <a href="../SBS_Commands.pdf">SBS Commands</a>.
typedef enum
    SBS_NONE = (-1),                 //!< (-1) No Command / Address
    SBS_REPEATABILITY_CLOCK_HIGH_ENABLED    = 0x3022C06,  //!< 0X2C06 enabled
    SBS_REPEATABILITY_CLOCK_MEDIUM_ENABLED  = 0x3002C0D,  //!< 0X2C0D enabled
    SBS_REPEATABILITY_CLOCK_LOW_ENABLED     = 0x3002C10,  //!< 0X2C10 enabled
    SBS_REPEATABILITY_CLOCK_HIGH_DISABLED   = 0x3022400,  //!< 0X2400 disabled
    SBS_REPEATABILITY_CLOCK_MEDIUM_DISABLED = 0x302240B,  //!< 0X240B disabled
    SBS_REPEATABILITY_CLOCK_LOW_DISABLED    = 0x3022416,  //!< 0X2416 disabled
    SBS_REPEATABILITY_CLOCK_MPS_HIGH        = 0x3022032,  //!< 0X2032 0.5mps
    SBS_REPEATABILITY_CLOCK_MPS_MEDIUM      = 0x3022024,  //!< 0X2024 0.5mps
    SBS_REPEATABILITY_CLOCK_MPS_LOW         = 0x302202F,  //!< 0X202F 0.5mps
    SBS_REPEATABILITY_CLOCK_MPS_1_HIGH      = 0x3022130,  //!< 0X2130 1 mps
    SBS_REPEATABILITY_CLOCK_MPS_1_MEDIUM    = 0x3022126,  //!< 0X2126 1 mps
    SBS_REPEATABILITY_CLOCK_MPS_1_LOW       = 0x302212D,  //!< 0X212D 1 mps
    SBS_REPEATABILITY_CLOCK_MPS_2_HIGH      = 0x3022236,  //!< 0X2236 2 mps
    SBS_REPEATABILITY_CLOCK_MPS_2_MEDIUM    = 0x3022220,  //!< 0X2220 2 mps
    SBS_REPEATABILITY_CLOCK_MPS_2_LOW       = 0x302212B,  //!< 0X212B 2 mps
    SBS_REPEATABILITY_CLOCK_MPS_4_HIGH      = 0x3022334,  //!< 0X2334 4 mps
    SBS_REPEATABILITY_CLOCK_MPS_4_MEDIUM    = 0x3022322,  //!< 0X2322 4 mps
    SBS_REPEATABILITY_CLOCK_MPS_4_LOW       = 0x3022329,  //!< 0X2329 4 mps
    SBS_REPEATABILITY_CLOCK_MPS_10_HIGH     = 0x3022737,  //!< 0X2737 10 mps
    SBS_REPEATABILITY_CLOCK_MPS_10_MEDIUM   = 0x3022721,  //!< 0X2721 10 mps
    SBS_REPEATABILITY_CLOCK_MPS_10_LOW      = 0x302272A,  //!< 0X272A 10 mps
    SBS_READ_SERIAL_NUMBER    = 0x3023780,  //!< 0x3780 Serial Number
    SBS_FETCH_DATA            = 0x306E000,  //!< 0xE000 Fetch Data
    SBS_ART_MEASUREMENT       = 0x3022B32,  //!< 0x2B32 ART Periodic Measurement
    SBS_BREAK                 = 0x3023093,  //!< 0x3093 Break
    SBS_SOFT_RESET            = 0x30230A2,  //!< 0x30A2 Soft Reset
    SBS_I2C_NRESET            = 0x3020006,  //!< 0x0006 I2C_nReset
    SBS_HEATER_ENABLE         = 0x302306D,  //!< 0x306D Heater enable
    SBS_HEATER_DISABLE        = 0x3023066,  //!< 0x306D Heater disabled
    SBS_READ_STATUS           = 0x302F32D,  //!< 0xF32D Hex: @see SBS_16_BITS
    SBS_CLEAR_STATUS          = 0x3023041,  //!< 0x3041 Clear status register
    END_SBS_CMD,               //!< End of SBS Command Definitions
} SBS_CMD;
