Din Rail mount for Raspberry Pi Pico
DIN rail housing with breadboard and power supply to mount a Pi Pico in control cabinets
RasPiBox Pico is an enclosure set for the new Raspberry Pi Pico microcontroller board by the Raspberry Pi Foundation. The heart is an additional pcb with integrated voltage regulator and breadboard. It fits together with the Raspberry Pi Pico in a 4 module DIN rail enclosure.
Overview:
  • milled 4 module DIN rail enclosure
  • top shell with grey or transparent cover
  • for EN50022 DIN rails
  • pcb with 2x 20pole female pin headers to plug a Raspberry Pi Pico
  • optional integrated voltage regulator (input voltage 9..35V via 2 way terminal block)
  • breadboard / proto board for own circuits
  • all GPIO pins are marked and placed beside the breadboard area
  • 3x 2 way terminal blocks to connect external components to the breadboard
  • removable protections for terminals
  • Opening for Micro USB socket of the Pico on top side
Adobe Portable Document Format - 860.23 kB - 09/15/2021 at 15:11
Preview
Download
View all instructions
