Autonomous Litter Detection Robot w/ Edge Impulse
Recognize and monitor litter with object detection via this self-driving robot. It also deploys a video stream and a fall detection system.
Even though knowing mentioned pernicious consequences, unfortunately, we pollute the Earth with our waste even more quickly than it recuperates and replenishes itself. If this incessant and interminable polluting continues to expand, it will eventually stymie ecosystem cycles and instigates the process of petrifying portents to become our day-to-day reality. While the Earth has been deluged with our waste, the imminent danger of waking to an unrecoverable world approaches. Therefore, in this project, I focused on contemplating a solution to avert waste from spreading and expanding.
In terminology, littering is the improper disposal of waste products. Although littering can happen intentionally or unintentionally, litter can cause serious and pernicious consequences for the environment[1]:
1) Litter causes water, soil, and air pollution. As litter degrades, chemicals and microparticles are released. These chemicals aren’t natural to the environment and can, therefore, cause several problems. They can make their way into the soil and freshwater sources, impacting both humans and animals regardless. Also, researchers estimate that more than 40% of the world’s litter is burned in the open air, inducing toxic emissions. These emissions can cause respiratory issues, other health problems, and even acid rain.
2) Litter kills innocent animals every day. Researchers estimate that over one million animals die each year after ingesting or becoming entrapped in improperly discarded waste. Plastic litter is the most common killer of animals, and marine animals are the most notably affected.
3) Litter facilitates and expedites the spread of diseases through direct and indirect contact. Improperly discarded waste is a breeding ground for bacteria, viruses, germs, and parasites. Germs can be transmitted directly by physically interacting with litter. Bacteria, parasites, and infectious pathogens can be transmitted to humans indirectly through an affected vector. Vectors are animals or insects that contact with contaminated litter and then transmit those contaminates to humans.
Examining landscapes to find scattered litter requires an unreasonable workload and is challenging economically even before starting to clean up. Since one of the biggest problems in fighting the waste invasion is to find the littered locations before it is too late to avert waste from spreading, I decided to develop this autonomous (self-driving) robot that tracks and monitors litter with object detection. With the assistance of this robot, it is effortless to search and find the littered areas with a minuscule workload. Even if it is a small step, I hope this prototype will be beneficial and practical in fighting the waste invasion.
I employed Edge Impulse to build a neural network model for detecting litter with object detection under these three categories:
  • Bottle (glass and plastic)
  • Can (metal)
  • Packaging (plastic, paper, cardboard, etc.)
Edge Impulse also provides a live video stream after being connected to Raspberry Pi. So, I did not have to create a webcam server (Motion) to be able to live stream with Raspberry Pi for this project.
After training the model and running it on Raspberry Pi, I designed and assembled my autonomous litter detection robot with an RPLIDAR A1M8 360 Degree Laser Scanner (Lidar), a robot chassis, and a USB webcam. Then, I built a fall detection system with an Arduino Nano and a 6-axis accelerometer for the robot to forfend it against crashes.
So, this is my project in a nutshell 😃
In the following steps, you can find more detailed information on coding, data collection, and building a neural network model with Edge Impulse.
Huge thanks to DFRobot for sponsoring this project.
Sponsored products by DFRobot:
⭐ RPLIDAR A1M8-R6 - 360 Degree Laser Scanner | Inspect
⭐ DFRobot Black Gladiator - Tracked Robot Chassis | Inspect
⭐ DFRobot Serial 6-Axis Accelerometer | ...
fritzing.fzz
fzz - 79.14 kB - 11/02/2021 at 12:35
Download
lidar_litter_detection_robot_accelerometer.ino
ino - 3.73 kB - 11/02/2021 at 12:35
Download
LIDAR_Litter_Detection_Robot.py
x-python - 7.21 kB - 11/02/2021 at 12:35
Download
  • 1 × Raspberry Pi 4 Model B
  • 1 × DFRobot RPLIDAR A1M8-R6 - 360 Degree Laser Scanner
  • 1 × DFRobot Black Gladiator - Tracked Robot Chassis
  • 1 × USB Webcam
  • 1 × L298N Motor Driver Module
View all 15 components
  • 1
    Connections
    // Connections
    // Raspberry Pi 4 :
    //                                L298N Motor Driver Module
    // GPIO 17 ----------------------- IN_1
    // GPIO 27 ----------------------- IN_2
    // GPIO 22 ----------------------- EN_A
    // GPIO 10 ----------------------- IN_3
    // GPIO  9 ----------------------- IN_4
    // GPIO 11 ----------------------- EN_B
    // Arduino Nano :
    //                                DFRobot Serial 6-Axis Accelerometer
    // D11 --------------------------- TX
    // D12 --------------------------- RX
    //                                SSD1306 OLED 128x32
    // A4  --------------------------- SDA
    // A5  --------------------------- SCL
    //                                Buzzer
    // D10 --------------------------- S
  • 2
    Assembling the Tracked Robot Chassis
    First of all, I assembled the DFRobot Black Gladiator (Tracked Robot Chassis) and connected an L298N motor driver module to the robot chassis to control its DC motors easily with Raspberry Pi GPIO pins.
    ⭐ Install the load-bearing wheel (first install the M4*50 long screw into the load-bearing wheel) and lock the other side with the M4 screw.
  • 3
    ⭐ Place the gasket on the bracket and insert the load-bearing wheel into the hole of the bracket. Then, seal it with the other gasket and the M4 nut.
View all 15 instructions
Kutluhan Aktar wrote 09/16/2021 at 20:38 point
Please feel free to leave a comment here if you have any questions or concerns regarding this project 😃
