Status bar is here.
A project log for Smart Response XE word processor.
Pocket typewriter thing, intended for light-to-moderate text editing, without distractions a more advanced device would bring.
abundanceofpotentialusesAbundanceOfPotentialUses 10/31/2021 at 22:320 Comments
So I got distracted by the freshly added USB feature, and I adapted the USBaspLoader (to be precise a more up-to-date fork by Stephan Bärwolf), this bootloader is compatible with avrdude. I think the only changes needed were pin assignements, and like 6 lines in the main include to add support for atmega128rfa1 (copy-pasted from atmega1284 because they're almost the same, except for the radio part). And it worked right away. And it's actually faster than the hardware ICSP dongle I was using.
Then I spend more time crafting nicer and more convenient to install USB port boards...
But eventually, I got around to implementing the status bar: it lists battery status (as in voltage), current page, size of the current page in bytes and words(for NaNoWriMo), and gives a rough estimate of your place on the page.
Function keys are now:
The project is now published on github. Though the code is a mess.
To do:
