ComeNCapture 3.0
Crappy STM8L and F-RAM based logic capture SUMP OLS compatible.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
[W.I.P] This is ComeNCapture 3.0, the next generation of project ComeNCapture 1.0 and ComeNCapture 2.0 . Inspired by Logic Shrimp project by Dangerous Prototypes.
Specification :
- 8 Channels with 5 volt tolerance.
- Maximum capture rate at 16MHz.
- 128k Samples (at 16MHz and below) by using FM25V01 F-RAM.
- SUMP OLS compatible.
- Small size (3.2x3.2cm) for portability. (Actually smaller PCB is cheaper xD).
- USB-C connector with USB 2.0 CH330N USB to Serial UART baud rate at 57600.
