Hackaday.io Hackaday.io
Sign up Log in
Inverted pendulum on a cart
Building an inverted pendulum system with PID control. Trying to achieve swing-up.
dharshan-bashkaran-lathaDharshan Bashkaran Latha
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.7k views
1 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 10
    • View all
  • Logs 9
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
3.7k
1
2
1
Team (1)
  • dharshan-bashkaran-lathaDharshan Bashkaran Latha
Join this project's team
MISC
ongoing project
Inverted Pendulum control Robotics
This project was created on 09/22/2021 and last updated 4 years ago.
Components
  • 2 × 470mm 2020 Aluminum profile
  • 4 × 90mm 2020 Aluminum profile
  • 4 × 100mm 2020 Aluminum profile
  • 12 × 2020 aluminum corner L-clamp
  • 3 × 8mm steel rod (500 mm length) 2 for guide, 1 for pendulum
View all 10 components
Project Logs
Collapse
  • Test #3: Ultrasonic sensor HC-SR04
    Dharshan Bashkaran Latha • 05/01/2022 at 09:20 • 0 comments
    Using a HC-SR04 ultrasonic sensor to track the position of the cart.
    Limiting the minima to 10cm and maxima to 45cm (~10mm clearance)
    I used a cardboard cut-out to mount the sensor, and also as a rebound surface,
    Although the least count is 1cm here, the reading seems to be pretty precise.
  • Test #2: Seeed magnetic encoder
    Dharshan Bashkaran Latha • 04/12/2022 at 14:36 • 0 comments
    Testing the magnetic encoder sensor from seeed with my Inverted pendulum system.
    Magnet used: 5mm NdFeB cube Magnet
    Used a basic code of I2C comm.
    The sensor was very accurate and consistent.
    Looking forward to integrate the Ultrasounic range sensor next.
  • Test #1: Stepper motor test
    Dharshan Bashkaran Latha • 04/11/2022 at 15:31 • 0 comments
    Inverted pendulum system using a Nema17 stepper motor, driven by Microstep driver
    Controlled by a Rotary encoder interfaced using arduino uno.
    inferences:
    • Better control achieved.
    • Pulsed motion.
    Further developments:
    • Program modification for smoother motion
    • Need to verify structure integrity.
  • Test #0: Motor and mechanism trial.
    Dharshan Bashkaran Latha • 10/27/2021 at 16:48 • 0 comments
    Inverted pendulum system using 12V 775 DC motor, driven by L298N motor driver.
    Controlled by a joystick interfaced using an arduino uno.
    observations:
    - Irregular and abrupt motions.
    - Motor unable to provide enough torque
    - difficulty in precise controlling of the motor
    inferences:
    - Driver limitations 2A output per channel. Hence, could not provide enough torque for smooth            transmission.
    - Mechanism is smooth without the motor involved.
  • Final assembly
    Dharshan Bashkaran Latha • 10/27/2021 at 16:13 • 0 comments
    Complete assembly - belt, pulleys and electronics
  • 3D printing
    Dharshan Bashkaran Latha • 10/27/2021 at 16:10 • 0 comments
    PETG - 3D printed parts:
    1. Pendulum rod holder
    2. Motor holder
    3. Idler pulley holder
    4. Sensor holder
  • Assembly
    Dharshan Bashkaran Latha • 10/03/2021 at 14:22 • 0 comments
  • CAD model
    Dharshan Bashkaran Latha • 10/03/2021 at 11:38 • 0 comments
    Black parts are 3D printed parts. STL files to be uploaded soon.
  • Materials
    Dharshan Bashkaran Latha • 09/24/2021 at 06:19 • 0 comments
    Attaching images of items procured.
    Meanwhile designing models that need to be 3D printed - motor mount, base plate, etc.
    Soon to upload CAD models of the setup
View all 9 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
adarshgovi wrote 05/03/2023 at 22:04 • point
I saw that you used a cube magnet with the Seeed magnetic encoder, but my understanding is that the AS5600 chip requires a diametrically polarized magnet which I am having trouble finding. Did you find that it worked well with the cube magnet? Is there anything special about the magnet in terms of polarization?
A compact motor for home automation control of small roller blinds
Project Owner Contributor
A compact roller blind motor
paul-wallacePaul Wallace
The objective of the project is to create a precision linear motor by using an diy optical encoder similar to those used in printers.
Precision linear motor with diy photo encoder
mrozomrozo
Cheap 3d printed hi torque robot actuator with electronics
Hi torque 3d printed cheap robot actuator
pavel-gPavel G.
WiFi connected mini-blinds opener using ESP8266 microcontroller.
WiFi Blinds - ESP8266 IoT Device
paul-fjarePaul Fjare
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Inverted pendulum on a cart", please tell us the reason.
Send message
Remove Member
