Commit 98d33ef
Mostly component optimizations based on v1 power supply design with MAX1771 boost controller.
3 different inductor values are tested: 15uH, 47uH, and 150uH. 47uH seems to be the sweet spot for maximum current output @ 12V input.
Hottest spot on the power supply reaches thermal equilibrium @ around 65 degrees C.
