Development Launch ~ Nov. 2020
A project log for GameCubePC
The complete GameCube computer that replicates original functionality and adds several new features without sacrificing performance
retromodderRetroModder 09/24/2021 at 20:520 Comments
This project was originally started with the goal of fitting a complete Windows 10 PC inside of a GameCube case, with the major requirement of running Wii and GameCube at full FPS and native resolution using Dolphin Emulator. Additional goals were set to retain full functionality of the original buttons, controller ports, cooling system, and more. Based on the specifications of the Mini-STX form factor, I knew one of these motherboards would barely fit inside of a GameCube shell.
Using a Dremel to hollow out the inside of the bottom shell quickly turned into an ugly JB-welded mess, and there was still no good way to firmly mount the motherboard to it.
While pondering the bottom shell issue, work continued on wiring the original front controller ports to a GameCube controller USB adapter. A connector with the correct pitch was spec'd out that allowed an interface to be established with the original controller port board.
The controllers being passed through to the USB adapter was a success, and was able to get the adapter to function in both PC (D-Input) and Wii-U mode in Dolphin. Because of a lack of USB ports on the motherboard, a custom PCB was designed to handle the addition of 4 ports in the memory card slots using a third party low-profile USB hub. There is only one internal USB 2.0 header on the motherboard, so the GameCube controller USB adapter uses one port and the 4-port USB hub uses the other.
A 3D printer was necessary to make the build clean looking. After many tweaks to match the curvature of both the inside and outside of the front panel, some standoffs and USB port covers were produced.
The bottom shell was also designed, and only a few prints were required to get the base very close to the original shape. Motherboard I/O access and a slot for the front controller port panel to rest in were also added.
Standoffs for the original GameCube screw posts were needed to adapt the top half of the case to the PC motherboard's mounting pattern. A cover was also printed that goes above the motherboard rear I/O shield, and has mounting holes for the WiFi and Bluetooth antennas.
Features
Future fixes
