Mechanics FAIL Rince Repeat
A project log for Arc Delta 3D PCB Drill (and other failures)
Arc Delta PCB Drill and 3D Printer (perhaps later)
hacker404Hacker404 11/20/2016 at 02:490 Comments
OK, I have encountered some problems with the mechanics.
The first was the floppy arm lol. One arm was used as a guide when drilling the 8mm holes for the motor shafts so it was a bit of a loose fit.
I kept tightening it but eventually the Stainless Steel M3 screw just snapped so I found some bolts at the hardware store and upgraded them to M5.
The next problem was binding of the bearings to the hex shaft so I added some spacers. These spacers are still a little to large so I have ordered some thin tube to make spaces with a smaller outer diameter.
The original setup was line this -
Now I have removed one of the hex shafts to make way for the spacers. I also files the middle section of the hub flat to make it easier to mount a motor.
Also the original power supply was intended for the smaller stepper motors that I was first using and it only had the capacity to drive one of the new steppers so it had to be upgraded to -
