Pump House Monitor
Monitoring the outdoor pump house that pulls water from a well to supply the house with water.
0 followers
This project is going to start as only temperature monitoring combined with an alert to give a warning if the pump house is getting close to freezing. Eventually, I want to add a pressure sensor as well to alert if the pump is not working correctly.
  • First Edition
    Kody Alan Rogers09/25/2021 at 16:27 0 comments
    I just set up a basic temperature monitor in the pump house using the MKR WiFi. The code currently has no alert system enabled, but that is next on the list.
    Also, I know the instructions are not very good and hopefully, they will be improved at a later date.
View project log
  • 1
    Wire the board
    Place the AM2302 sensor on the board along with the MKR 1010 and wire them together following this great article on Adafruit: https://learn.adafruit.com/dht/connecting-to-a-dhtxx-sensor.
  • 2
    Set up a 'Thing' on the Arduino IoT cloud
    I configured the 'Thing' with one variable (a float) to hold the temperature and I called it inner_temperature. If you have not configured an IoT cloud 'Thing' before I would check out this great tutorial: https://docs.arduino.cc/cloud/iot-cloud/tutorials/iot-cloud-getting-started.
  • 3
    Upload the Code
    If you upload it from the Arduino IDE ensure the 'Thing ID' is correct since your 'Thing ID' will be different from mine.
    If you upload it from the browser editor then you should be able to just copy and past the .ino code from the Github and hopefully, it will work.
View all 3 instructions
ten93881 wrote 07/22/2023 at 08:12 point
The Pump House Monitor from nitenitestore. is a game-changer! It offers real-time monitoring and control of my pump system, ensuring I never have to worry about water levels or malfunctions. As a homeowner, this device brings immense peace of mind, and I highly recommend it to anyone looking for efficient pump management.
