First Edition
A project log for Pump House Monitor
Monitoring the outdoor pump house that pulls water from a well to supply the house with water.
kody-alan-rogersKody Alan Rogers 09/25/2021 at 16:270 Comments
I just set up a basic temperature monitor in the pump house using the MKR WiFi. The code currently has no alert system enabled, but that is next on the list.
Also, I know the instructions are not very good and hopefully, they will be improved at a later date.
