Flexible circuit wind generator
A new way to generate wind energy using only polyester film based flexible circuits
This project involved the development of a brand new type of wind generator called a FLAG; a Flexible Linear Aeroelectrostatic Generator. It uses the motion of a flexible circuit to generate electricity.
A FLAG is made by cutting thin polyester film into the required shape, surfacing it with a pattern of conductive areas that make it work as an electrostatic machine, and then folding the plastic into the final shape of the generator. When exposed to the wind, the generator oscillates, and the relative motion of the conductive areas extracts work from the wind, allowing the circuit to harvest electricity continuously.
This demonstration prototype requires only plastic film, conductive tape, and three diodes (no 3D printing required). Imagine a future with lightweight power generating kites, flags, and leaves!
A FLAG is one of the first thin film technologies successfully prototyped for outdoor wind power.  It is essentially a self-actuated-air-valve made of thin plastic film, combined with an electrostatic machine.  This simple, lightweight, inexpensive, easily manufactured, and recyclable technology is a new way to generate small scale electricity.  FLAGs can have the appearance of flags, or leaves, and are light enough for airborne wind power.
The generator is surfaced with conductive areas called "sectors", that generally act as variable capacitors.  Either mechanical contact switches, or diodes are also used to strategically transfer charges between sectors, so that the mechanical work of pulling the oppositely charged sectors apart can generate electricity.  A number of different harvesting circuits have been successfully prototyped in combination with the aerodynamic oscillator.  This particular FLAG build uses diodes, and the circuit used is depicted below.
C1 is essentially a variable capacitor consisting of three sectors, each mounted onto one of three layers of the polyester film. The inner sector can move back and forth between the other two, and the charge on C1 is increased by a factor of 2 each reciprocation (if connected to ground).  This design is not connected to ground for ease of construction, so the factor is likely reduced to 1.6.  C2 is an energy storage capacitor, which is not absolutely necessary but improves the reliability of the machine and size of the output current pulses.  The circuit is similar to one described in De Queiroz, A. C. M. (2016). Energy harvesting using symmetrical electrostatic generators. 2016 IEEE International Symposium on Circuits and Systems (ISCAS). doi:10.1109/iscas.2016.752732, except this circuit uses the equivalent of a three plate variable capacitor, instead of two synchronized variable capacitors, and there is no true ground connection.  Elimination of the ground connection simplifies the construction, and electrically likely causes that part of the circuit to "bounce" in polarity as the generator runs.  The lack of a ground connection should have an impact on performance, but the impact has not been obvious in testing.
The generator is made of one piece of polyester film, cut and folded into three layers.  The outer layers have holes which cause the inner layer to oscillate in the wind.  The inner layer of film blocks one set of holes, causing air to flow through the opposite set of holes, which "sucks" the inner film to the opposite side, blocking the opposite set of holes.  This ultimately creates a very stable and repeatable oscillation over a wide range of windspeeds.
The FLAG prototypes operate at windspeeds in the approximate range of 15-50 km/h.  The thinner films are lighter, and have a lower cut-in speed, but theoretically cannot operate at as high of voltages.  At 20 km/h, the oscillating frequency is in the range of 10 Hz.
Since the conductive surfaces are open-to-air, the output is affected by humidity.  The generator is self-starting and works well up to 60% humidity, depending on the materials used.  At low humidity they have run at up to 2 kV (occasionally causing breakdown of the polyester film).  Higher operating voltages result in significantly higher power outputs, so future improvements should include fully enclosing the conductors in polyester.
The two other thin film technologies that have been attempted for wind power applications are piezoelectric films, and TENG (triboelectric nano generators).  FLAG has some advantages over these technologies including the use of non-specialty materials, low cost, and relative insensitivity to humidity.
NOTES TO HACKERS/MAKERS:
 ● Recently, the circuits needed to cheaply and efficiently convert pulses of high-voltage-low-current to more useful voltages have been...
FLAG Instructions.pdf
Detailed instructions with photos explaining how to make a thin film wind generator.
Adobe Portable Document Format - 6.73 MB - 09/26/2021 at 16:37
Preview
Download
ms-excel - 1.33 MB - 10/10/2021 at 22:44
Download
  • 1 × polyester film .002" - .005" thickness, at least 7" x 24"
  • 2 × conductive tape 3M 3190 - 10.3x10 sheets
  • 3 × diodes 1N4007, or M100FF3
  • 1 × load T4 fluorescent light bulb 8-16Watts, or 100 LED's in series with small spark gap
  • Fractal switched capacitor converter testing #1
    Stuart MacKenzie11/10/2021 at 07:05 0 comments
    The FLAG prototypes are able to light at least 98 LED's wired in series, fluorescent lightbulbs, or any loads that like a high-voltage-low-current output.  Wouldn't it be nice to convert the FLAG output to a low-voltage-high-current output for powering electronics, or to trickle charge a small battery?  Historically this conversion has been difficult to do efficiently for influence machines.
    Just in time, comes the invention of the FSCC (Fractal Switched Capacitor Converter)!  This converter circuit was developed at Chongqing University for a different type of generator with a similar output to a FLAG.  The FSCC charges capacitors in series, and discharges them in parallel, in such a way that it works like a transformer, at high efficiency (94%), and with minimized voltage drop from the diodes.
    I ordered the diodes (1N4007) and capacitors (22nF) from Digikey, and built the 96 unit FSCC converter circuit from the paper on a breadboard, to give it a try with the FLAG.  To operate, the FSCC requires that a switch is contacted on every stroke of the FLAG, so I made a small flat switch that fits inside the FLAG.  Ideally, it should be contacted at the moment the inner layer is flat against the outer layer.  With all the effort I went through to remove the surface contact switches from the FLAG, I'm not thrilled to add one, but this is just a test to see if this new type of transformer will really work.  Below is a picture of the switch-  it is folded over and bent with a small kink in it so that it will stay open until the FLAG squeezes it a little each oscillation, closing the circuit.
    Before the FSCC, the FLAG could not light any LED's in parallel-  it only makes enough current to light a lot of LED's in series.  On this first attempt, the FSCC allowed the FLAG to light 17 LED's in parallel including 2 large LEDs (12 shown in the below video).  I find this hugely exciting!  With a properly designed FSCC, FLAGs will be able to efficiently produce any voltage required, at high efficiency.
    I could see in this test, it was important for the switch to open and close at the correct time and with good contact, which was affected by the angle and amount of kink that I put into it. When I gave the switch too much kink, the LED brightness would decrease.  Ideally the switch should be removed completely and replaced with a solid-state solution.  In my attempts to make adjustments to the switch, I unfortunately damaged it before I could make any measurements, but that leaves something fun for next time.
    Even the tiniest movements of the film caused the LED's to light, which is also exciting for future developments.  The first FLAG attempts operated at very high frequency and were held under some tension, with more of a vibration like motion at approximately 50Hz and only moving a couple of millimeters.  I can see how operating the FLAG under tension like that would increase the power output-  perhaps by a factor of 5, since that would be the relative increase in oscillation frequency.  The shorter stroke would also mean that more layers could be fit into the same volume (another multiplier for power output per unit volume).  Higher frequency designs seem well suited for kites, which by their nature are held in tension.
    As this FSCC was not custom designed to match the FLAG output, I'm sure the efficiency could be improved.  It should also have two switches, one for each of the two end positions of the center layer of film.  That means the LED's in this test were blinking half as often as they would with two switches.  In the future, I would like to try this again with two better designed switches, and a slightly smaller FSCC.
    Below is an image of the apparatus from this test.  You can see the 96 unit FSCC took two poorly-planned breadboards, although Chongqing University fit the same circuit onto one...
  • Cutting machine files
    Stuart MacKenzie10/30/2021 at 16:23 0 comments
    The links to the Cricut cutting machine files are in the assembly instructions PDF, but they are also included below.  In order to use these, you would need a Cricut cutting machine, and to have Cricut Design Space installed.
    FLAG polyester cut file link
    FLAG conductors cut file link
    FLAG sectors cut file link
    FLAG assembly image link
    I am not aware of a way to directly convert these Cricut files to the SVG file format for other cutting machines.  If you have a different type of cutting machine, I think it would be necessary to open these files in the free Cricut Design Space software, print them as images, and then convert the images to SVG.  If you prepare the SVG files, please send them to me so I can make them available for others here!
  • FLAG Project History #10
    Stuart MacKenzie10/14/2021 at 07:04 0 comments
    I have been discussing FLAGs with companies that may be able to produce them with improved manufacturing using conductive-inks and other flexible printed circuit technology.  I am looking forward to seeing FLAGs that have the somewhat natural appearance of leaves, or multi-cell, multi-layer designs, with higher oscillating frequency, and fully encapsulated designs to increase the power output.
    One of the greatest advantages of the FLAG is that this type of design is extremely lightweight.  Even the converter circuits required do not use heavy coils and magnets. Time permitting, I would like to make the first flying FLAG kite...!  It will be interesting to see how far the idea can be pushed.
    I am also experimenting with circuits that will efficiently convert this type of high-voltage-low-current output, to more useful low-voltage-high-current output.  Traditional coil transformers do not work well in this application.  The type of circuit needed was recently invented and demonstrated at high efficiency (Fractal Switched Capacitor Converter), and an attempt to make a similar converter circuit for the FLAG is in progress:
    I do not really have the right measurement equipment to properly size the components of this circuit, so I am using the highly advanced method of trial and error.  It is not immediately obvious from the Fractal Converter paper (which was developed for a different type of generator with similar output characteristics), but it requires a switch to trigger the circuit at the right moment of the FLAGs motion.  I have had some mild success but it is not yet working as well as I would like, and I would prefer to come up with a design that is entirely solid state.
  • FLAG Project History #9
    Stuart MacKenzie10/14/2021 at 06:58 0 comments
    In order to make FLAG experimentation accessible to people without 3D printers, I developed the design that was submitted for the 2021 Hackaday Prize.  It can be made with only a sharp knife, plastic film, conductive tape, and 3 suitable diodes.  If you have a Cricut cutting machine or know somebody with one, it will be a much quicker way to cut out the pieces and links to the Cricut files are provided in the instructions.  The simplified design has a downside in that it can put repeated bending stress on the diodes, and the leads on some diodes will occasionally break.  I'm sure somebody will come up with a better way to mount the diodes that will still not require the 3D printed parts.
    The Hackaday Prize FLAG design has been tested outside in humid conditions:
    And this design has even mounted to my truck antenna to go for a drive, with a little bit of foam to make sure it wouldn't short out on the antenna:
  • FLAG Project History #8
    Stuart MacKenzie10/14/2021 at 06:44 0 comments
    Here is a picture of the test apparatus I set up to make some measurements of the FLAG output.  You can see my electric field meter near the center which I bought off ebay many years ago (and I have great doubts about its calibration and accuracy).  I have it mounted 1" from an aluminum plate which is charged by the FLAG, and is also connected to a large TDK UHV-2A ceramic capacitor so I can calculate the output current by seeing how long it takes to charge the capacitor with the FLAG while monitoring the voltage with the electric field meter.  The electric field meter is connected to my multimeter, which is connected to my laptop with an optical connection so the data can be recorded on my computer without risk of accidentally exposing it to the high voltage output of the FLAG.  The fieldmeter is a Prostat PFM-711A.
  • FLAG Project History #7
    Stuart MacKenzie10/14/2021 at 06:33 0 comments
    I really wanted to demonstrate the FLAG powering loads other than fluorescent light bulbs, so I set about getting it to light up LED's.  LED's act a little more like a direct short across the generator output terminals, so it is necessary to put them in series with a spark gap so that there is enough load on the generator to keep it operating at high voltage.  There have recently some interesting publications about using very small spark gaps to improve the performance in electrostatic harvesting systems (Plasma Switch), so I ordered some ultra-fine tip tungsten needles (0.6 µm radius tip) and machined a mount for them out of nylon.  Under a microscope I carefully adjusted the gap, and I have been using this spark gap to light my LED's ever since (picture below).  Prior to doing this, I have used a much more ordinary spark gap using a couple bolt heads, and it worked fine as well.  In case you're wondering why one of the tungsten needles is a little bent in the below photo, I accidentally dropped it while putting this together,  and had to straighten it again.  When the FLAG is lighting the LED's through the needles, you can see a nice glow emanating coming from the tips.
    Here is a picture of 98 ordinary LED's being lit in series (blinking at about 10 Hz, partial brightness).  This was my first attempt, so I do not know the maximum number of LED's that can be lit in series with a FLAG:
  • FLAG Project History #6
    Stuart MacKenzie10/14/2021 at 06:29 0 comments
    Trying to identify the causes of success and failure, I built over 200 prototypes, using different designs and materials.
    What I eventually realized, was that plastic film materials intended for printing cannot be used.  The pre-treatments given to plastic for printing seem to cause adsorption of humidity from the air, giving them poor surface resistivity.  I also discovered problems with insulating the generators with tape.  My theory is that charges migrate through the tape adhesive, and build up there-  creating a parasitic capacitance with the sectors that eventually stops the machine.
    Using no insulating tape, and only insulating using polyester film, I started to get consistent results.  I carefully designed the generator so that all the oppositely charged conductors are on opposing film surfaces, or have a large distance between them.  These two things combined allowed the generator to be self-starting at up to 60% relative humidity, and with a "jump start", it will run at higher.  I believe the power output can be increased significantly by encasing the sectors within the polyester, but this sort of manufacturing is beyond what I can do at my desk.
  • FLAG Project History #5
    Stuart MacKenzie10/14/2021 at 06:25 0 comments
    The poor humidity performance and unreliable switching was persisting, so at this point I decided to get rid of the surface contact switches altogether and replace them with diodes.  I also changed the design to get better separation of the oppositely charged areas, and started trying different materials and insulating the generators with tape.  I also bought a Cricut cutting machine to make the generators more quickly with the time I had available.  I tried some designs with the diodes housed in a 3D printed mast, and very simple 3 or 4 diode harvesting circuits.  This is a 3-sector design, with no storage capacitor:
    The design later progressed to having the diodes mounted in small 3D printed swivel rings that can slide over the fluorescent light itself, or over a piece of acrylic tubing if I want to try powering some other kind of load.  The rings are 2-pieces, and are put together with a small zip-tie, which squeezes the ring a little bit and pinches the electrical connections between the diodes and the conductive film.  You can see on these generators, I'm using small elastic bands to restrict the distance that the generator opens in the wind.  One nice thing about this design, is that the electrical connections are secure, and there are no sliding contacts or subject to repeated stress.  The use of diodes instead of surface contact switching allowed for a design with all the oppositely charged surfaces to be very physically separated, which really improved the performance in ordinary air humidity.  Variations of this overall design are still among my favorites, but they require a high resolution 3d printer:
  • FLAG Project History #4
    Stuart MacKenzie10/14/2021 at 06:07 0 comments
    After the first successful prototype, I started making more generators in this style, mostly by hand.  I refined the design a little bit;  I gave it some supports so it could be hung from an acrylic rod or directly from a fluorescent light.  I also put the power output on those supports, so I would no longer need to use alligator clips when testing.  Here is an example, where you can see the power outputs (+ and -) on the outside supports, and the "ground" connection (approximately equivalent to a "neutralizer" on a Wimshurst machine) on the center support.
    As the generators oscillate very quickly, whenever one wouldn't work I often couldn't tell what the problem was. For troubleshooting, I built a "stroboscope" by hacking into an automotive timing light and adjusting the strobe timing with an arduino.  With my stroboscope, I could turn out the lights, and adjust the frequency of the strobe light to be close to the oscillating frequency of the FLAG.  This would create the optical illusion of the FLAG moving in slow motion to help me troubleshoot it.  The light beam was a little too narrow to make the illusion perfect, but it was good enough to be helpful.
    The slow-motion on the newer iPhone models has become so good, the stroboscope was quickly retired.
  • FLAG Project History #3
    Stuart MacKenzie10/14/2021 at 06:04 0 comments
    It was May 2018 when I had the first successful test of a FLAG, oscillating in the wind to power a light.  Despite trying many different variations and circuits, you will notice the design still looks very similar to the original 4-sector 3-layer acrylic test shown in the last log.
    In order to make the generator oscillate in the wind, I took a rectangular piece of polyester transparency, folded it in half, and cut out rectangular vent holes.  A second piece of polyester goes inside the "V", and when held in the wind, the center film oscillates at a fairly high frequency.  The center film covers one set of holes, causing the air to pass through the opposite holes, which essentially sucks the center film to the opposite site...  over and over, at high speed.
    The harvesting circuit and sectors stuck onto the film was made using ordinary aluminum foil tape, with the tips folded over wherever an electrical connection was needed.  Alligator clips were connected from the bottom two connections to power a fluorescent light.  The tabs of tape sticking out were what I used to hold it in the airflow from my "wind tunnel", and holding it relatively fixed like this makes the generator oscillate at much higher frequency.  This is something I still wish to experiment with further, as the latest FLAG designs run at a much lower frequency.  Generally speaking these sorts generators will theoretically make more power per unit volume at higher frequencies, with less travel, and more layers.
    After all the effort in getting to this point, I had the first working FLAG framed.
    The generator still had some problems to be sorted out.  It still seemed to be sensitive to humidity, and the mechanical contacts were still unreliable.   More to come in the following logs.
View all 12 project logs
  • 1
    How to Build a FLAG
    Here are some detailed instructions on how to build a FLAG, with lots of photos. These instructions are for making one using a Cricut hobby cutting machine, and there are links to all of the Cricut files in the instructions.  A hobby cutter is easiest, but the patterns can also be cut out with a sharp knife and patience.
    FLAG Instructions.pdf (hackaday.io)
    This is a demonstration design, intended to be as easy as possible to make and not requiring any 3D printed parts.  It is not intended for extended use or high performance.
View all instructions
zackperry79 wrote 11/26/2021 at 00:02 point
Awesome job!! Its concepts like this that truly puts the "CAN" in Canada keep up the good work my fellow countryman!!
the_3d6 wrote 11/21/2021 at 03:59 point
From what I can guess, power output should be in low microwatt area for a reasonably sized device, so that hardly can be of any practical use
Stuart MacKenzie wrote 11/21/2021 at 07:08 point
If you look at the included files, the power calculations are in the excel spreadsheet.
The power output for a single layer, single cell, uninsulated generator of this size is pretty low-  you can’t run a motor with it or anything like that.  The power output is also quite sensitive to the operating voltage, so a properly insulated unit could be expected to have much higher output.
Every tech has to start somewhere.  In its current form, with a switched capacitor converter circuit, it will be able to run low power electronics.  I think that with more development, there are a number of ways the output can be increased for applications beyond blinking lights.
the_3d6 wrote 11/21/2021 at 10:07 point
I actually missed your calcs - but they are close to what I guessed (I expected something around 50 uW, you have ~400 at 3 kV and correspondingly ~65 at 500V you stated in the table).
But after seeing them, I have nothing to really add. You did the experiment - with quite reasonable implementation - and you believe that better design will lead to x100 higher efficiency (and that you can pack them really dense to reach stated m^3 power). I instead see tons of problems and doubt it can be realistically brought to better than x10 of your results in terms of power generation, and am way more pessimistic about packing it in volume.
It would be great if I'm wrong though
Stuart MacKenzie wrote 11/21/2021 at 18:11 point
The numbers you have stated are incorrect.  The demonstration FLAG output at 500V was measured to be at least 0.4 mW.  For comparison, a conventional wind turbine of the same area and at the same windspeed as shown in the spreadsheet would make maybe 5 mW, due to the low tip speed ratio in small sizes.
The explanations for how the power output can be increased substantially by increasing the oscillating frequency, and operating voltage have already been described in the project details and logs.
the_3d6 wrote 11/21/2021 at 20:04 point
I read your table more carefully and realized what I'm missing. In closed position you have 1.7 nF capacitance - while I was guessing that your system can have about 100 pF max.
50 um contact while flapping wasn't something I thought was realistic - yet you have it.
That explains what I missed in its physics and why my power density estimations were so much different from your data. With such parameters it looks much more attractive, although still needs 10x improvement to be practical - but that may be achievable
Machinehum (Ryan Walker) wrote 11/03/2021 at 22:16 point
This is super cool
Paul McClay wrote 10/17/2021 at 07:31 point
Persistence FTW
Walker Arce wrote 10/15/2021 at 15:17 point
Impressive!  I look forward to seeing where your technology goes.
Stuart MacKenzie wrote 10/25/2021 at 22:56 point
Thank you! Me too, I hope some others try to make their own and improve them.
Krzysztof wrote 10/14/2021 at 19:28 point
Fractal switched capacitor convertors - this is the thing I needed and I thought that such thing must exist already. Now, this will be the new hotness for ion - flyer drones :)
