Cutting machine files
A project log for Flexible circuit wind generator
A new way to generate wind energy using only polyester film based flexible circuits
stuart-mackenzieStuart MacKenzie 10/30/2021 at 16:230 Comments
The links to the Cricut cutting machine files are in the assembly instructions PDF, but they are also included below.  In order to use these, you would need a Cricut cutting machine, and to have Cricut Design Space installed.
FLAG polyester cut file link
FLAG conductors cut file link
FLAG sectors cut file link
FLAG assembly image link
I am not aware of a way to directly convert these Cricut files to the SVG file format for other cutting machines.  If you have a different type of cutting machine, I think it would be necessary to open these files in the free Cricut Design Space software, print them as images, and then convert the images to SVG.  If you prepare the SVG files, please send them to me so I can make them available for others here!
