Here is a 2-cell 18350 battery caddy that may be used instead. This was the original setup before I fabricated custom contact pieces. This caddy is a tight fit and the edges should filed or sanded as needed. It slides into the compartment upside down at an angle. Keystone Electronics (part #1102) available from major parts distributors.
