PCB Annotations added to silkscreen
A project log for ABNielsen.com 6502 SBC r0
Complete 6502 single board computer with 50x29 lines "VGA" output and PS/2 input
anders-nielsenAnders Nielsen 10/30/2021 at 12:260 Comments
I always tend try to get things into production fast. This has a tendency to involve limited redundant information - said another way: I don't add silkscreen information already present on the schematic.
I believe I've reached a point where I know another revision of this board is coming eventually , so I decided to add some silkscreen text - if nothing else, so I don't forget that the broken out data and address busses have LSB on the left when the VGA port is pointing away from you :)
Note: The Gerbers.zip hasn't been updated this time - if you are about to send them off to manufacture, maybe replot them from Kicad :)
