Introduction
In printed circuit boards, the base of the board is the primary part of the circuit. And, we have studied the substrate used as the base in PCB. But, that substrate is not thermally efficient. To meet the needs of high thermal products, here comes the metal core PCB. MCPCB is the abbreviation of the metal-core printed circuit board. It is also popular as the thermal PCB. It contains the metal material as its base. This material is usually copper or aluminum covers one side of the PCB
The main purpose of the metal core is to change the direction of heat away from the printed circuit board. Hence, it transfers the heat eight to nine times faster than the simple PCB. It also keeps the components cool. As a result, efficiency and performance of for it increases. It prevents the circuit from damages.
Metal Core PCB
JLCPCB is the foremost PCB prototype & manufacturing company in china, providing us with the best service we have ever experienced regarding (Quality, Price Service & Time). We strongly recommend ordering PCBs from JLCPCB, all you need to do is just download the Gerber file and upload it to the JLCPCB website after creating an account as mention in the video above, visit their website to look for more!.
Thickness and Material for Metal Core
Metal Core PCB
  • The thickness of the material uses in metal core PCB is normally 30 mil to 125il. But more than thicker or thinner from this range can be practical for desired circuits.
  • Usually, aluminum is widely used for this purpose. Copper or heavy copper is also used sometimes. Other materials like steel and brass have been used too. However, they are not recommended or preferable.
