Had some issues suspending it above the desk using a skeleton arm... So I just added legs to this version. Currently designing the veneers for it to make it look a little better. The time of flight sensor is now used to initiate one of the animations loaded into the ESP32. It will then cycle through. Now for looking into a good way to "dust" the surface.
Dan
Snoopymeoww
Jeff Haag
Adam Jensen
Thanks!
