Basic Hacker MultiBench
A one stop shop with fixed 5V/12V/24V/USB metered power, adjustable power supply, voltmeter, continuity tester and basic oscilloscope.
Public Chat
It is probably a rite of passage for any hardware hacker to build their own bench supply but with limited desk space I wanted to add a few more standard features that would mean I had everything in one place. I had a basic list of needs: 1. Current measuring and supply of 5V, 12V, and 24V 2. Variable power supply with current limiting 3. Continuity tester 4. Voltmeter 5. USB Power 6. Oscilloscope – ok, not essential but I had it lying around – sue me. 7. Low cost – not meant to replace the good stuff Most of the effort has gone into the 3D case for components and power supply. I have tried to do this in a modular fashion in OpenSCAD to allow the configuration to be changed. The main components of this are DSP3005 Programmable Power Supply (~$28) a 24V, 120W 5A PSU (~$17) and a DSO150 basic oscilloscope (~$50 for an original). The rest are standard parts like volt/ammeter, voltmeter, binding posts, switch, connectors, dc buck converters, DC to USB
I have uploaded initial photos and instructions but I can enhance these more if there is interest.  3D stl files and OpenScad model is now uploaded for printing and customisation
I will probably create a separate project for the AtTiny85 continuity tests.  It is a very simple project but is also a good introduction to the AtTiny85 DigiSpark (and clone) boards.
Most of the wiring connections are now shown in included images.  I will also add images next for the PSU, switch, fuse and XT60 connector
External 24V 5A power brick (rear)
JPEG Image - 219.17 kB - 01/18/2022 at 23:38
Preview
External PSU (Internal)
JPEG Image - 250.21 kB - 01/18/2022 at 23:38
Preview
Overview showing size when using an external power brick
JPEG Image - 100.85 kB - 01/18/2022 at 23:38
Preview
MultiBench.scad
OpenSCAD script for building all parts
scad - 16.47 kB - 01/18/2022 at 23:22
Download
MultiBench Back (Jack).stl
Barrel Jack input to back instead of full PSU
Standard Tesselated Geometry - 353.01 kB - 01/18/2022 at 23:21
Download
View all 15 files
  • 1 × DPS3005 Step-down Power Supply module Voltage converter LCD voltmeter 30V 5A
  • 1 × 24V 120W Switching Power Supply Mains powered 24V 5A power supply
  • 1 × DSO150 Oscilloscope Kit Basic oscilloscope kit for frequencies up to about 100KHz
  • 1 × Voltmeter DC 0-100V Mini LED Digital DC 0-100V Voltmeter
  • 2 × Voltmeter / Ammeter 4 digit DC 0-100V 200V 10A 4 Bit 5 Wires Voltmeter Ammeter
View all 22 components
  • External Power Brick Option
    John Gilmour01/18/2022 at 23:49 0 comments
    To reduce the desktop footprint I have added an option for an external power brick.  It is equivalent to the internal one i.e. 24V 5A so requires a mod to the rear to take a 5.5mm x 2.5mm barrel jack panel mount socket.  This also avoids anyone messing with mains voltage.
    I did not want this to stick straight out the rear stopping it from being pushed to the back of my desk so I have angled it so that the plug is mostly enclosed and the wire drops down from the rear.  Makes it a neater job.
    I have updated the OpenSCAD file to include this, added an stl file for it and added some photos to show the internal and external change.
    Been busy on other projects so only posting this now.  Any questions just add to the discussion
  • A note on Ammeters and Voltmeters
    John Gilmour10/16/2021 at 14:27 0 comments
    A few comments on the voltmeters and ammeters. First on the housing.  These all come with shells that click into a hole quite easily.  This would have made the 3D model simpler but they need more space and I wanted a nice line and symmetry below the DPS3005 so the best way was to create the mounting in the 3D model. In my case the bare voltmeter/ammeter board are a friction fit but you can use a little hot glue if they are not sitting in correctly.
    Second thing is accuracy.  These are cheap voltmeter/ammeters.  In most cases we are just not looking for precision, just a rough value, most of these are accurate to about 0.1V and some can be tweaked with a small potentiometer on the board so look out for that if it is important.  Generally it is fine and I don't have to pull out a proper multi-meter.
    When connecting to the ammeter it seems strange to connect the thick red wire to the black binding post but since this is the current coming from the load and the thick black wire is connected to 0V it makes sense.  Just follow connections from the load.
  • Uploaded PSU Wiring
    John Gilmour10/15/2021 at 23:46 0 comments
    Uploaded pictures of the PSU back case with wiring.  Using fork type crimps bent to fit the case to allow the safety cover to click in place while still sliding back into the case.
    Mains live wire passes through a 3A switch before connecting to the PSU live mains terminal to allow for local isolation.  The 12V line connects via an inline fuse before being soldered onto the female XT60 connector.
    Added a little strain relief on the mains cable with a tie wrap to prevent the cable being pulled out.  I don't intend to move this much so should not get much stress.
    Note: do not work with mains electricity unless you are confident working with this.  Use a 24V 5A power brick and swap to a barrel jack rated at >5A.
  • A Note on Heat and Air Flow
    John Gilmour10/14/2021 at 15:33 0 comments
    There are 6 dc - dc buck convertors in this project, while not as inefficient as linear regulators they can still get toasty.  If the supplies are only getting light use the there is probably no need for a fan, just make sure that you have the base raised (using stick on rubber feet) as there are some holes underneath for air flow.
    If you are ramping up the amps then a bit of assisted airflow is worth considering.  I have included mounting holes for a 60mm x 60mm x 15mm fan on the inside of the main unit.  I have a few of these on order from AliExpress to try it out but not needed it yet.
    If you have the full unit with the power supply then the fan will pull air though the main unit and push it through the PSU so the one fan should do the job.
    The LM2596S Dual USB Power Supply Module is fairly cheap (~$1.5) and can churn out 3A (2A + 1A).  If they are being pushed above 2A adding a small heat sink would be recommended (only cost a few cents but I had a couple spare from A4988 driver boards)
  • Uploaded wiring diagrams
    John Gilmour10/09/2021 at 23:58 0 comments
    Wiring diagrams are now shown in png images.  This covers meters, binding posts, 12V/24V selector switch, barrel socket and DPS3005.  Buck convector wiring for DSO150 has been added but best to follow the JTech instructions to build the oscilloscope.
    Note, when you are building this oscilloscope it is very easy to get it wrong if you not follow the pictures on the JTech guide.  Particularly soldering the encoder switch to the correct side of the additional board.
  • Uploaded Diagram for Voltmeter and Continuity Tester Wiring
    John Gilmour10/09/2021 at 19:37 0 comments
    Diagram for Voltmeter and Continuity Tester Wiring has been added.  Programming can be done with continuity.ino file.
  • Uploaded Diagram and Code for Continuity Tester
    John Gilmour10/09/2021 at 17:41 0 comments
    The continuity tester uses an AtTiny85 Digispark board, one resistor (close to 50ohm) and one active buzzer.  Also only needs one line of actual code (excluding pin settings) and is a nice starting project for using the AtTiny with total project cost about $2 (+postage).
    Files are:
    • Continuity.ino
  • Uploaded 3D Files
    John Gilmour10/07/2021 at 21:51 0 comments
    Added 3D stl files and OpenSCAD file for customisation.  Also available on thingiverse: https://www.thingiverse.com/thing:4988627
View all 8 project logs
  • 1
    Before you start
    This is an intermediate level project and assumes familiarity with buck converters and soldering.  The space is tight and may require a little adjustment of wires as components are added.  The PSU is an optional part of the build but is fully integrated.  The PSU involves working with mains voltage so do not do this part if you are not use to working with mains voltages (because…death etc).  An alternative is to get a 24V 5A brick supply and add an XT60 female connector.
  • 2
    Build First
    Solder red/black wires to the two LM2596 converters and set the voltage to 12V and 5V (24V input)
    Solder red/black wires to the MP1584 converter and set voltage to 9V (24V input) and cover with clear heat shrink
    DSO150 – Build the kit and connect the MP1584 converter in place of the 9V jack
    Continuity Tester – Solder the buzzer and resistor to the ATTINY85 board and program Solder together the Voltmeter, Continuity Tester and selection switch and cover the attiny with clear heat shrink
  • 3
    Build Order
    Screw in all of the binding posts (6 posts, 2 sockets as in picture) with 1 nut
    Screw in the DSO150 (4 short screws for the main board, 2 long for encoder switch and 1 long for the analogue daughter board
    Slot in the slide switch, voltmeter
    Screw in the 5V LM2596 converter to the side panel beside the DSO150
    Slide in the LM2596S Dual USB Power Supply (don’t screw in until all wiring done)
    Run wire between the two LM2596S Dual USB and onto the LM2596 converter
    Slot in the volt/ammeter to the centre and connect to 5V and posts as per diagram
    Slot in the volt/ammeter to the side and connect to on-off-on switch and posts as per diagram
    Screw in the 12V LM2596 converter to the side panel below the DPS3005
    Connect the DPS3005 output to the binding posts and barrel jack socket
    Solder wires to the XT60 panel mount male connector and connect to all 24V inputs as per diagram (you can solder these together or use a lever nuts)
View all 3 instructions
excitedbox wrote 10/16/2021 at 03:18 point
This is awesome. I have actually been planning a project similar to this but based around a soldering station. I am still working on the layout of the individual components before I start designing the controller board.
Since a soldering station has a pretty strong PSU and a hot air station needs plenty of air, most lab devices/tools can be powered off those, bringing the costs way down. For example my current soldering station has a 800W power supply which would be plenty to run a 30v 10A power supply while the iron is off. There is no reason to have both when you can't use both at once.
So far I am planning on:
Devices
-Reflow oven
-Board heater
-Air filter
-Power supply + usb charger
-multimeter
-transistor tester /lcr meter
-temp sensor
-7" display
-light / light ring
-Parts drawer, tip cleaner, etc.
Hand Tools
-Solder iron
-Hot air
-solder sucker
-soldering tweezers
-paste dispensing
-vacuum pick/place
-digital microscope
-3rd hand
I am open to adding other things that would use the same components such as an esp32, stm32, Atmega or maybe an additional ADC or other IC as long as it is not too expensive.
John Gilmour wrote 10/16/2021 at 13:20 point
I had planned to add a few of these things but it was getting out of hand.  Had planned to incorporate a component tester but was not good fit without a custom board design and was just not worth the hassle for the time I use it.  I have a pick-it-up bead vacuum tool but I am working on a smaller 12V unit but separate from this.  I have a different, but very simple, reflow oven design based on rocketstream's code with an esp32 or esp8266, might publish that.
The 3D print took multiple redesigns, days and days of test prints so decided to keep it to what was sensible with reasonably priced stuff that I would use.
gulliverrr wrote 10/14/2021 at 05:07 point
I may be missing the info somewhere but what is the LCD on top for? It looks like a Raspbian (with the HDMI bridge and microUSB power connectors sticking out on the side). It is related to the project or is it simply stacked on top?
John Gilmour wrote 10/14/2021 at 12:24 point
@gulliverrr The main picture shows a few things on my bench, second picture homes in on the multibench.  The one you are talking about is another thing I am working on. It will be a case with a capacitive touch TFT, pi4 and a cheap $8 logic analyser. Still working on this but looking to get sigrock on the pi and the logic analyser in the case.  Case will be the same dimensions as the multibench so that I can stack it or put it side by side.  I have stacked it because I want to use the screen with my microscope for pcb inspection and smd work.  The pi also has the IoTStack on github from @Andreas Spiess so I can manage home automations stuff through this (mosquitto, NodeRed, MotionEye and maybe Home Assistant).  Coming soon (along with some other stuff).
Lightning Phil wrote 10/10/2021 at 10:13 point
Nice work.  A function generator and inexpensive LCR bridge would be nice add ons.  Get's cluttered when cramming all that in.  So shoehorn more stuff in and add Bluetooth audio and a light :)
John Gilmour wrote 10/10/2021 at 17:52 point
Function generator would be a good idea, never used an LCR bridge, just have a couple of component testers that are only occasionally used.  I had more elaborate plans but I want to finish other projects.  Main deciding factor for what I could fit was the power supply dimensions and the stuff I thought I would used for PCB testing, stepper and servo powering and checking led chain current requirements.
Lightning Phil wrote 10/10/2021 at 18:14 point
If you do try cramming all that lot in, it becomes an unmanageable mess to use due to all the cables on the front :)
Didn't put a scope in my one (somewhat smaller and built into a console type case) as all the scopes are big standalone things (except one that's in a guitar pedal).
You probably don't need an LCR bridge unless doing a lot of work making audio crossovers.  Some component testers can have a fair bash at that too.
JVS wrote 10/09/2021 at 19:59 point
Noice! follwing
