Water filling pace
A project log for Anteneh’s Jerry Can
A new kind of Jerry can for water transport for rural areas that ease the pain for the person carrying the load with lower cost.
Anteneh GashawAnteneh Gashaw 10/24/2021 at 18:050 Comments
For people who fill water into a Jerry Can using a small can, it is very time consuming because the water inlet hole has small diameter and you will take longer time when you are pouring the water from the small cup. Anteneh's Jerry Can will solve this problem because the new Jerry Can have large diameter and will take less time to fill depending on the filler speed.
