Material science
A project log for Anteneh's Firearm Bin
A new mechanism that can prevent bullet casing and burned propellant released in to the environment.
Anteneh GashawAnteneh Gashaw 10/25/2021 at 17:140 Comments
Anteneh'sfirearm bin is made from a waterproof and heat resistant fabric material. This is because when the bin is used in the rain if it is not made to be waterproof it will absorb moisture and will have more weight which is problematic for the user. Since Everytime you fire your gun there will be heat generation, the bullet casing will have a small heat at an immediate fire ejection which makes it damaging to the bin if it is not made to be heat resistant.
