Aim
A project log for Anteneh's Firearm Bin
A new mechanism that can prevent bullet casing and burned propellant released in to the environment.
Anteneh GashawAnteneh Gashaw 10/25/2021 at 19:190 Comments
When I asked firearm experts about the possibility of having a technical problem when using a firearm which have Anteneh's firearm bin installed in it, they told me it has a small possibility. Meaning, people who use firearm like pistol don't usually use the aiming part of the gun because it's a smaller range firearm which is good for your product but for smaller portions of people who use the aiming part it might be problematic because it could block it. For larger range firearm since the product is installed at the side, it will not affect the aiming function of the gun.
