Usage direction
A project log for Anteneh's Firearm Bin
A new mechanism that can prevent bullet casing and burned propellant released in to the environment.
Anteneh GashawAnteneh Gashaw 10/25/2021 at 19:440 Comments
Whenyou are using Anteneh's firearm bin you don't have to carry the collected bullet casing in your pocket or the bin. When you are in situation where it's not efficient for you to carry the collected bullet casing you can eject the bin containing the casing and dispose it at will. When matter is the bullet casing don't end up in the environment at random places apart from each other which is hard to collect. Then you can switch another bin to replace the disposed bin.
