3d-printed solder stencil printer box
Get perfect solder stenciling every time with a few springs and some 3d-printing
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I been working for quite some time trying to make the process of solder stencil printing as streamlined and as simple as possible. I have made several machines, some even with up to 5 axis and motors. However the solution im the most happy with is what i ended up with after working together with Seon the Unexpected Maker.
We where collaborating on vacuum bed designs for our stencil printers, when i saw the possibility to just have a simple vacuum box, and drop the madchine it self.
By adding some simple battery springs from JLCPCB (2usd for 6 of them), i made a simple mechanism that lifts the solder stencil when the box looses it vacuum. Which so far ends up with precise soldering each time.
