Relay Controlled hot air (Dragon)
A project log for IR Everything
Multiple IR triggered creations with an IR blaster to make the magic happen
seanSean 10/14/2021 at 04:170 Comments
Not much to say here. It's exactly the same as the blacklight, just with a slightly different relay and different load. I'll be getting a 120V compatible relay with standard plugs that I can plug either a hair dryer or heat gun into.
