• OLED housing print #1 -- review
    Martin Cejp2 days ago 0 comments
    • LCD opening should be a bit larger (~0.5 mm each side) to accommodate viewing angles; probably should be chamfered as well
    • interior slightly too small (~0.5 mm in each axis), making the PCB rotate a bit
    • opening for connector should be 1.6 mm to match PCB thickness (instead of 1.0 mm)
    • opening for connector could be ~1 mm narrower
    • 2.0 mm thickness should be enough for walls (instead of 2.5 mm)
    • apparently STL was in millimeters. mistake in export from Blender?
    • next prototype should incorporate holes for screwing the PCB in
    • thanks, Nuno!
