Flash Erase, Write, Verify
A project log for µPy FT10
Porting MicroPython to the FT10 Smart Watch
marblemarble 01/18/2022 at 21:590 Comments
After using the flashing tool to create a flash dump for backup reasons, I read a 8kiB (0x2000) section of the start of flash and then wrote it back using the User Data feature of the tool.
The MessageBox logs two EraseFlash and then two consecutive WriteFlash and VerifyFlash events.
This is also visible in the captured signals. I also tested the Chip Erase function of the tool and captured its operation and response code. By checking the numbers of bytes transmitted, recording more examples and using reveng I found more uses of the CRC.
Protocol PhaseOp/RespCodeParameters: length
TX: erase sectorb"\x87\x30\x10"- address: 4B
- lengthb"\x00\x10\x00\x00": 4B
- CRC-16/ARC: 2B
RX: acknowledge erase sector
b"\x87\x30\x10"- stuffing (b"\x00"): 5B
- CRC-16/ARC: 2B
TX: erase 16 sectors
b"\x87\x35\x10"- address: 4B
- lengthb"\x00\x00\x01\x00": 4B
- CRC-16/ARC: 2B
RX: acknowledge erase 16 sectorsb"\x87\x35\x10"- stuffing (b"\x00"): 5B
- CRC-16/ARC: 2B
TX: erase allb"\x87\x31\x10"- CRC-16/ARC: 2B
RX: acknowledge erase allb"\x87\x31\x10"- stuffing (b"\x00"): 5B
- CRC-16/ARC: 2B
TX: write
b"\x87\x32\x10"- address: 4B
- length: 4B
- payload: nB
- CRC-16/ARC: 2B
RX: acknowledge write
b"\x87\x32\x10"- stuffing (b"\x00"): 5B
- CRC-16/ARC: 2B
TX: verify
b"\x87\x50\x10"- address: 4B
- length: 4B
- CRC-16/ARC of flash content: 2B
- CRC-16/ARC: 2B
RX: acknowledge verifyb"\x87\x50\x10"- stuffing (b"\x00"): 5B
- CRC-16/ARC: 2B
