Sketch - Second Version
A project log for TRICORDUINO - 3.0 True Scientific Tricorder
This project describes the development of a multi-mode scanner platform, which can be described as a Scientific Tricorder .
antonio-cesar-de-oliveiraAntonio Cesar de Oliveira 11/22/2021 at 13:520 Comments
11/22/2021
          Tests done during a storm, showed excessive sensitivity of the AS3935 sensor. So I had to add command lines in the code to render better sensitivity control. The new version of the sketch uses byte noiseFloor = 4 and byte watchDogVal = 4.
